New product to protect C7 skid plates!
#61
So basically it's a piece of plastic that gets gorilla glued to the metal chevy OEM part. Is that correct?
#62
E-Ray, 3LZ, ZER, LIFT
Received 9,624 Likes
Much better than the terrible noise of aluminum on pavement! On the last time I hit one in my C6 it dented. Fortunately did not have to replace, not cheap!
#63
Supporting Vendor
Yep. Rugged plastic molded to fit exactly. Need to remove the black paint and use the Gorrila glue provided. Easy install.
Bui if you want more detailed information You can go to this link.
http://www.saccitycorvette.com/C7Fangs.html
Thank you,
Norma
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
#64
Order placed. I have a very steep driveway, and had a moment of quality panic today pulling out onto the street, where a very long scratch was laid down on the driveway. Turned out to be a rock that got trapped under the front right tire while braking, but made me think that these are a required addition.
#65
Supporting Vendor
Norma
SacCityCorvette
#66
Supporting Vendor
Fangs from SacCityCorvette provide the best possible protection available for your front skid Plates/Lower Radiator support on your C5/C6/C7 Corvette.
