Auto Transmission - speed vs. rpm
TRANSMISSION OVERALL
4.03 10.32
2.36 6.04
1.53 3.92
1.15 2.94
0.85 2.18
0.67 1.72
Rear axle 2.56 (base model), approx 1507 rpm @ 70 mph, tires 245/40X18 front, 285/35X19 rear
For speeds in gear, you can do the math as you choose. Don
4.03 10.32
2.36 6.04
1.53 3.92
1.15 2.94
0.85 2.18
0.67 1.72
St. Jude Donor '08
Not sure of what you want but here is the WOT shift points for both Speed and RPM for the C7 A6. I believe both have to be satisfied for it to shift.
As you can see, at 5000 RPM's and 169 MPH it will be shifting to 6th gear at WOT.
Check out my post here for RPM vs MPH for A6 vs M7 performance ratios vs the A4 in my SS.
http://forums.corvetteforum.com/1584616957-post26.html
