Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
- C5 C6 Corvette: How to Disable Skip Shift (CAGS)
Step by step instructions for do-it-yourselfers...
C7 Corvette Stingray Skip Shift Eliminator - CAGS - 1 to 4 eliminator!
#141
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
I love my 2015, it is an amazing car, my skip shift does activate during heavy traffic, I remember the first time it happened I thought something was wrong with the car, I quickly learned on this forum what was actually happening. My question is: is it bad to let the car do what it is suppose to do and that is just go to 4th gear, then if necessary, I then usually down shift to 3rd and then 2nd? This is what I have been doing especially in heavy traffic, usually the skip shift doesn't come on because under normal conditions I am shifting at a higher rpm. Just curious if I am doing any harm to this awesome vehicle? Thank you to all experience corvette guys out there, like I said this is my first vett and I am really enjoying it.
GM did not put that in because it helps the car! Most normal folks folks driving a Corvette will seldom, if ever, shift at that low rpm from 1st gear! Especially if they see the traffic moving in front of you and assume you'll accelerate but instead you're shifting to 4th at a low rpm, then shifting to another gear with car continuing to coast! If that was their girlfriend calling -they may be distracted for the few seconds needed to hit you! I'd suggest getting a "skip shift eliminator" and if nothing else avoid the chance of a rear end collision!
#142
IMO CAGS was a bigger problem on the C6 than the C7. I hit that 1– 4 shift lockout often on my C6 before I added an eliminator. I ordered an eliminator for the C7 before the car even arrived but drove the car for a few weeks before installing it.
CAGS kicked in only once, in heavy traffic. Still, it’s an unexpected annoyance when it happens.
But… maybe I’m just driving more aggressively in the C7(?).
#143
Like Pavlov's Dog, Unfortunately For Some Folks Having to Look at a Beeping Cell Phone in a Learned Conditioned Response!
#145
Regards,
Dave K.
#146
Some devices look different and the one I have has the two plugs tied togeter with wire. Somce don't. It's not needed. The resistor in mine is in the end that plugs into the harness to the computer. the other plug stops dirt from getting into the plug on the trans. If in two parts, that's fine.
I also have a Z51 and the bottom plug, as you note, is for a trans temp sensor. The upper plug on the drivers side goes to the shifter blocking pin solenoid, which is what you want.
#147
Nope, it works in all modes. Would not be a problem if it only worked in ECO mode, since I never use it!
This all has to do with the EPA required drive cycle to measure mpg. If you look in the Owner's Manual at suggested shift points for best economy that is probably similar to what they use.
Note there is no shift to 2nd and 3rd since skip shift would active if shifting out of 1st at the recommended 17 mph! The 4th to 5th shift is at 25 mph; 5th to 6th at 40 mph and 6th to 7th at 45 mph.
Can't imagine driving that way!
#148
Thanks.
#149
I haven't installed the CAGS yet, many times I skip shift into 3rd instead of 4th and I haven't had any issues. Is anyone else doing this? Is this bad for the engine, I know I am not lugging the engine, just curious. This has been working for me without the CAGS, this is why I haven't installed it yet.
Thanks.
Thanks.
#150
Thanks.
Thanks.
Shifting to 3rd at that speed brings it to ~1100 rpm which is better but still not where I would operate the engine.
If you install CAGS device and shift to 2nd at 17 mph that is ~1500 rpm, much better IF you are going to shift out of 1st at that low of a speed!
I would shift out of 1st at a higher speed and avoid the forced shift altogether. That is what I normally do. However in bumper to bumper traffic if shifting at 17 mph or less it is far better for the engine and responsiveness, IMO to shift to 2nd. That is the reason I put this inexpensive device on my C7 as I had in my C6! I'll pick which gear I want to be in! If shifting out of 1st at 30 mph perhaps a shift to 3rd may be the most logical under certain circumstances.
#151
Other suppliers sell these, and I have wondered the same thing. I have seen some that not only have different plugs, but measure a different resistance..
I would like the supplier to confirm if a 12 ohm resistor is correct for the C7.
I am concerned that the plugs may be modified to "fit", but the resistance is not correct.
Could someone that purchased one for a C7 check the resistor value before installing it?
Obviously, there are variations of the connectors that work with the center partition...and the manufacturers are modifying the connector instead of using the correct ones.
#153
Hmmmmm...when someone wants to verify what suppliers are really selling, no one wants to answer.
Guess the only way to know for sure if vendor is selling correct bypass is to measure the true resistance of the CAGS solenoid on a C7. Not really very difficult to determine.
#154
Will this work with the c7 z06?
#155
Received 3,818 Likes
Isn't there one of these that simply plugs into the aux port?
#156
Just buy one that says it fits your year! The plugs are slightly different from the C6.
Can't get much easier to install. On "All Girls Garage" today one young lady said she was installing one for the reason I will, I'll have the car jacked up to replace brake pads! In her case they were installing an exhaust! Took her 2 minutes, real time!
Just reach up to the top of the trans, remove the OEM plug and replace it with one supplied that keeps out dirt. Then install the other supplied plug on the one just removed that goes to the computer. It just snaps together and has the resistor. Use the supplied wire tie to keep it from hitting anything!
#158
See post #157 from a Forum Vendor I have used them-excellect.
Buy one from them that fits a C7 and it's as simple as unplugging a connector, inserting what you see and using a wire tie to keep it tight to the trans! Any location with a lift can do it. Most dealers will as well. In fact next time you have an oil change slip the tech $20 bucks and they will do it! Just stand in the back of the open door in the service bay and ask the Tech!
