Wouldn't it be cool if the C7 exhaust stayed as loud as it is when it first starts?
Old 03-07-2014, 09:59 AM
gixxerbill
gixxerbill's Avatar
Default Wouldn't it be cool if the C7 exhaust stayed as loud as it is when it first starts?
Dang it sounds awesome when it starts cold in the garage in the morning. I would love it to stay that loud all day what about ya'll?
The following 2 users liked this post by gixxerbill:
kitesurfer (12-06-2016), thrilled (12-07-2016)
Old 03-07-2014, 10:00 AM
Diver Down
Diver Down's Avatar
Did you get performance exhaust?
Old 03-07-2014, 10:01 AM
Snorman
Scraping the splitter.
Support Corvetteforum!
Snorman's Avatar
Received 1,028 Likes on 486 Posts
St. Jude Donor '13-'14-'15
I'm pretty sure the NPP exhaust starts with the baffles open.
S.
Old 03-07-2014, 10:07 AM
F4Topgun
F4Topgun's Avatar
If you want it to stay loud all the time, just turn the mode adjustment off. Baffles will stay open all the time.
Old 03-07-2014, 10:19 AM
gixxerbill
gixxerbill's Avatar
Yes I have NPP and I have baffles open. But for the first minute or so when it first starts it's louder.
Old 03-07-2014, 11:20 AM
BigJoe
BigJoe's Avatar
Yeah, there definitely no way to be stealthy when starting the car. If you want to attract attention its great but when I go to work at 7am my 93 yr old neighbor gets blasted out of bed since my garage faces his bedroom.
Old 03-07-2014, 11:22 AM
gixxerbill
gixxerbill's Avatar
Eh he probably needed to wake up anyway. He can always take a nap later.
tlippy (12-06-2016)
Old 03-07-2014, 11:24 AM
KenHorse
KenHorse's Avatar
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,400 Likes on 1,365 Posts
St. Jude Donor '11-'12-'13, '16-'17-'18
That doesn't seem to work. I absolutely notice times the baffles still close (in Tour mode at least)
Old 03-07-2014, 11:26 AM
hifi875
hifi875's Avatar
does it have the fuse like the c6z did?
Old 03-07-2014, 11:33 AM
runutzzzzz
runutzzzzz's Avatar
What OP is trying to say is that after the car warms up, the exhaust note changes, which it does on my car too.
NPP is always open / set to OFF but something with the metals or something along those lines make the exhaust quiet down after 1 minute or 2.
Has nothing to do with the valves opened or closed.
The following 2 users liked this post by runutzzzzz:
FLATJ (12-06-2016), pdiddy972 (12-06-2016)
Old 03-07-2014, 11:48 AM
KenHorse
KenHorse's Avatar
I disagree. Even when set to OFF, there are times the butterflies still open and close, at least on my car.
It seems to be pegged to throttle position, vehicle speed and engine revs. I need to do a more empirical assessment of the details however but it is quite obvious the NPP isn't "open all the time"
bjones7131 (12-06-2016)
Old 03-07-2014, 11:55 AM
Duke/Earl
Duke/Earl's Avatar
Put it in Touring before turning it off. Will start quiet.
The C7 flapper valve is electronically controlled in lieu of vacuum controlled. In sport mode the computer is constantly opening and closing the flapper. In track mode it is open more of the time, but still not constantly.
Old 03-07-2014, 12:05 PM
runutzzzzz
runutzzzzz's Avatar
While you are correct, not in the case of what OP is stating.
With the setting on "OFF" The valves are open at idle.
As to what you are referring to, yes my valves close at certain RPMs especially low ones in 4th gear.
OP Is stating it would be nice to sound as raspy, throaty and deep as when you initially start the car.
Go listen for yourself and listing to the sound levels decrease with engine temperature.
Old 03-07-2014, 12:06 PM
Pete43
Pete43's Avatar
I 'll bet if you took off your mufflers to gain access to the butterflies on the engine side of your mufflers, there would be 2 screws holding each butterfly valve in place. (I think it's the same on the tailpipe end butterflies too)If you removed the butterfly valves you would get loud exhaust all the time and no check engine light. ( if you were to remove the wire to the electric motor that operates the valves)
Then you could still use your in car controls (tour, sport, track...) to make the car quiet or loud. But in V4 mode you would here the 4 cylinder drone sound when your exhaust was set to loud.
My brother and I did this on the throttle bodies on our ZX-14's. It helped a lot on the low rpm torque.
Old 03-07-2014, 12:19 PM
xp800
xp800's Avatar
My experience is the same. My Engine Sound Management = OFF.
Cold startup is awesome. Then it ramps down very noticeably after about 15-20 seconds over a span of just a few seconds.
There are 2 sets of valves on the NPP: ones forward of the muffs and ones in the tailpipes. Non-NPP has only the forward valves. I believe these front valves are to manage backpressure in certain conditions as well as taming 4-cylinder fart mode.
I also notice that even though my NPP is set to "open" all the time, there are throttle conditions (low RPM tip-in on upshifts especially) where the sound is quiet and then something "opens" at about 1700 RPM-ish. So I -think- this is the effect of the forward valves.
This tip-in behavior does -not- change with drive mode selection. At idle and most acceleration conditions, it's clear that my rear NPP valves are open.
I also wonder if this behavior is different between A6/M7; mine's M7.
Old 03-07-2014, 12:21 PM
Highway 61
Highway 61's Avatar
Location: Between Forest Lake and White Bear Lake in the Land of 10,000+ lakes
Wouldn't the exhaust sound louder in the garage just like it does going through a tunnel than it does when you're in open space?
AdventurePoser (12-06-2016)
Old 03-07-2014, 12:28 PM
NSC5
NSC5's Avatar
Received 1,100 Likes on 742 Posts
I bet the engine mixture, timing, etc. is different during cold start because the cats need to be heated quickly for EPA compliance. This would account for some of the difference in exhaust note.
Cold start "sounds" can be humorous. My 2006 GMC Duramax pickup has a fast cold warmup mode if it is below 32 degrees. Unlike gas engines the diesel starts at its 600 RPM base idle but after about 30 seconds it will begin to ramp up 100 RPM at a time until it finally reaches around 1200 RPM. While this is going on the turbocharger exhaust vanes are moved to their most restrictive position and the Allison transmission is used to load the engine but its output shaft is still locked. It sounds like a little jet engine on takeoff at this point. When my daughter was about 3 I had buckled her in her car seat in the back and then ran inside to grab the cell phone I had forgotten. During this time the engine went into its fast warm strategy and Anna thought the truck was leaving without me
To Wouldn't it be cool if the C7 exhaust stayed as loud as it is when it first starts?
Old 03-07-2014, 12:42 PM
ny32182
ny32182's Avatar
Corsa's on my C6, the same thing is noticeable, it is definitely louder idling for about the first 60 seconds.
My non-expert theory is that it likely has something to do with some parts expanding as they heat up.
Old 03-07-2014, 12:48 PM
Nicky43
Nicky43's Avatar
Mine is always louder at startup as well. It does not get any quieter when starting even if when I had put the car in economy mode before shutting it off.
I think it has to do with the sudden crashing of all the air molecules inside the pipes as the engine starts and then slowly calms down as the air molecules all get to moving in the same direction out the tailpipe. Just a theory.
Old 03-07-2014, 12:59 PM
Al Gumby
Al Gumby's Avatar
I would go with this explanation. Same thing happens with my C6 LS3 w/o NPP. They run richer on cold start-up.
Quick Reply: Wouldn't it be cool if the C7 exhaust stayed as loud as it is when it first starts?
