Antenna mount for the C7 - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 03-21-2014, 07:14 PM
KenHorse
Obama, the worst POS ever
Support Corvetteforum!
KenHorse's Avatar
Location: Aurora, OR - Obama taking credit for Trump's economy is like Hillary taking credit for Monica's BJs
St. Jude Donor '11-'12-'13, '16-'17-'18
Default Antenna mount for the C7
After much head scratching, I was finally able to figure out a path to route the antenna cables out the back of the C7 to the license plate antenna mount. And yes, the rear-view camera still works just fine and there is access for the trunk release button as well
This mount uses the license plate mounting holes to secure itself, is made polished stainless and is made by a local member of a Portland area Corvette club. This particular mount I used was the one from my C6 that I had a buddy mill out to clear the camera and allow for access to the trunk release.
The CB antenna has a quick release so when I don't need it, it's not there. The other antenna is the VHF/UHF one for my ham radio rig.
KenHorse is offline
Old 03-21-2014, 07:15 PM
george vee
CF Senior Member
george vee's Avatar
2015 C7 of the Year Finalist
Looks good
george vee is offline
Old 03-21-2014, 08:41 PM
Waytofastvette2006
CF Senior Member
Waytofastvette2006's Avatar
Ok I'm sure you have your reasons. But why ?? we have this thing called a cell phone and with the c7 all you have to do is push the button on the wheel
But if your going to mount a semi truck antenna on a c7 I think you did about as good of a job as it's ever going to be.
Waytofastvette2006 is online now
The Following User Says Thank You to Waytofastvette2006 For This Useful Post:
RPK (10-09-2018)
Old 03-21-2014, 08:48 PM
KenHorse
KenHorse's Avatar
CB is for club cruises (hence the quick disconnect so it doesn't have to be on the car if I don't need it) - we use it to coordinate. And no, I HATE the FRS crappy radios.
VHF/UHF is for me
KenHorse is offline
Old 03-21-2014, 10:14 PM
Cruiter
CF Senior Member
Cruiter's Avatar
On order: Torch Red Z51
Our club (and most clubs) use the inexpensive walki-talki. They're the size of your mic, no connected antennas, digital, and can be charged while riding with the USB port. They can go several miles on flat land and two - three miles in the mountains. Works well. FOr longer distance there's the cell phone as someone already mentioned. Also they don't need to be mounted somewhere and then hooked to a power source.
Just saying .....
VHF/UHF is for me
Cruiter is offline
Old 03-21-2014, 10:28 PM
NSC5
CF Senior Member
NSC5's Avatar
VHF/UHF is for me
Ken,
Your 2M/440 antenna may work just about as well inside given the RF transparency of most of the C7 materials. A magnet mount antenna (like the little MFJ flexible twin band jobs which are quite short) stuck to a small plate of magnetic metal sitting in the hatch area should work fine even if the whip has to bend its head slightly. That would keep you from needing any outside antenna except when you need communications with club members.
NSC5 is offline
Old 03-22-2014, 02:01 AM
KenHorse
KenHorse's Avatar
Originally Posted by NSC5 View Post
Ken,
I had the dual band antenna on my C5Z, C6 and now C7. I don't think it detracts from the looks, leaves no permanent marks and works fine.
Besides, all hams think antennas are beautiful!
KenHorse is offline
Old 03-22-2014, 07:38 AM
NSC5
CF Senior Member
NSC5's Avatar
Careful Ken, that is probably the thought process the guy pictured below got started with years ago There was a very old guy with an even more hideous setup that used to show up at area hamfests and I always thought of him as "porcupine guy" with all of the spikes sticking out from every surface of the car.
Seriously, you did a very neat installation
NSC5 is offline
Old 03-22-2014, 10:03 AM
stevelischynsky
CF Senior Member
Maybe the OP wants to also tune into truckers that still use CB. Why have the truckers not switch over to FRS?
stevelischynsky is offline
Old 03-22-2014, 10:39 AM
KenHorse
KenHorse's Avatar
Ahaha....I've seen cars exactly like that. Fortunately for me (and my wife), I'm not a fanatic. On the other hand.. my house has:
But I'm getting OT here...
KenHorse is offline
Old 03-22-2014, 10:40 AM
KenHorse
KenHorse's Avatar
Nah...just for club drives and cruises
KenHorse is offline
Old 03-22-2014, 12:41 PM
JoesC5
CF Senior Member
That guy should be ashamed of himself. He really should get that dent in the rear fender repaired.
JoesC5 is offline
Old 08-17-2016, 02:25 AM
atsugidad
CF Senior Member
atsugidad's Avatar
Question on your Ham Rig. My Vette is 2016 Coupe Z51. I am also Ham Operator (KI6VFW) looking to add VHF/UHF but not CB. What antenna is that? Any ground plane or bonding added and where? How is it working for you - Range etc? What Radio you using - mainly, what is your max power out and are you having any interference issues (if so - on what Band) with onboard Vette computers / electronics? Thanks in advance.
atsugidad is offline
Old 10-09-2018, 09:18 AM
gliot1
CF Senior Member
gliot1's Avatar
St. Jude Donor '12-'13
VHF/UHF is for me
Our club has tried a number of options as well, but nothing works as well as a CB on a group trip with 20+ cars. For my C6 I made my own bracket which allowed me to detach the part of the bracket that shows when not doing long club outings. I will be making one that fits my C7 now!
gliot1 is offline
Old 10-11-2018, 11:07 AM
Michael Griffin
Junior Member
Use the Zello app on your phone. Works Great Lose the antenna forever.
Michael Griffin is offline
Old 10-11-2018, 11:09 AM
KenHorse
KenHorse's Avatar
Unless you don't have an internet connection (which is very common in many areas)
KenHorse is offline
Old 10-11-2018, 11:48 AM
joemessman
CF Senior Member
joemessman's Avatar
You could use your cell phone as a CB radio with an app called Zello. Works like a champ! Most car clubs use that now for the last few years. CB radios are fun. But give Zello a try and log into the 21st century. Just kidding.
And you won't have to fasten all that crap to your car.
Woops! I see someone mentioned that app above me.
joemessman is offline
Old 10-11-2018, 10:09 PM
Gearhead Jim
CF Senior Member
Gearhead Jim's Avatar
St. Jude Donor '13
Ron-
The horizontal tab on an antenna bracket tends to block your rear camera even though the tab on the Mid America kit is offset to the left side a little. You'll want the tab as far to the left as possible, left edge of the tab should be even with the left edge of your plate frame or even further (unless your rear camera is different from mine).
I used the Mid America kit and modified the bracket to move to the left. Making your own is a better idea.
Running the cable out the back is a real PITA, Vern C. and Forrest R. helped me do mine.
Enjoy that new car!
Jim
Gearhead Jim is offline
Old 10-12-2018, 01:43 AM
KenHorse
KenHorse's Avatar
As I said above, not if you don't have an internet connection. No internet, no Zello...period
And believe it or not, cell phone coverage is NOT everywhere
KenHorse is offline
Old 10-12-2018, 03:02 AM
Grand Slam
CF Senior Member
Grand Slam's Avatar
In California, and I assume other states, it is illegal to use a walkie-talkie because it is not hands-free. It is legal to use a CB - probably because of the high usage by truck drivers.
Grand Slam is offline
Quick Reply: Antenna mount for the C7
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
