** New C7 Front License Plate Brackets Available from Top Flight Reproductions **
#61
thanks, was looking for something better than the OEM grille mount that does not block so much air flow. Z06s are cooling limited as it is. Sounds like a product that needs developing.....
#63
The lower mount that we sell may work with the addition of a foam gasket between the air splitter and the body of the car, see here on our website http://www.topflightrepro.com/corvet...brackets.shtml scroll down to the red C7 that has the air splitter. would you be willing to try for us for free? All I ask in return are some pics showing the bracket mounted to the car
#65
C7 Corvette Front License Plate Brackets
If you live in a state that requires a front license plate, we have two great solutions for your C7 Corvette. Both of the Top Flight Reproductions front license plate brackets allow more air flow than the standard GM grill mount and attach with just two fasteners. There is no drilling or modifications required to your corvette.
** Features of the "Low Profile Mount" include less blockage of air flow, a sturdy aluminum construction with a black powder coat finish that attaches using existing screws. **
** Features of the "Grill Mount" include a Slim-Line look, an increase in air flow through the grill compared to the GM mount as well as ease of installation. **
NOTE: The GM C7 and C6 Body Colored License Plate Frames (sold separately) can be used with all of the Top Flight Front License Plate Brackets to enhance the look of the front plate.
ORDER HERE: http://www.topflightrepro.com/corvet...brackets.shtml
C7 Front License Plate Bracket "Low Profile Mount"
Shown with optional GM colored frame
Mounts to the bottom of the lower front bumper using two existing screws
C7 Front license plate bracket "Grill Mount"
Return the GM Front License plate bracket P/N 22830069
back to us and we will issue you core refund
(the P/N is located on the back side of the part).
Mounts using the Fastener Kit shown below
Grill Mount Fasteners qty of 2 per kit
** Please note that these are not supplied with the above
"Grill Mount" Front license Plate Bracket. If you have the GM
Grill mount you can use the same two fasteners. If you do not
have the GM Grill mount you will need to order this fastener kit. **
#69
I see you are going a buy 1, get a 2nd license plate frame 50% off. Will this still apply if I get a Long Beach Red one for the front and a black one for the rear? The discount does not seem to be applying on your website so I have not placed the order just yet.
If I can get some way to confirm the discount, I will try to order a set tonight.
Thanks!
Thanks!
#70
Thanks!
Thanks!
Cromagnum (07-16-2016)
#71
I have one last question before I order. I see that you have an option for a black license plate frame. On the bottom half of my vette in the back, the color does not appear to be simply flat black. There is definitely some metal flake there (maybe carbon flash?). What color code matches that?
I plan to do Long Beach Red in the front to match the body color, but was not sure how different the black you offer differs from this one.
I tried to take a picture to show this.
#72
#74
#76
#78
When do you plan on having the new C7 2017 colors available?
Also, have Level Aero splitter on my 2017GS. Unsure if your Low Profile set up will fit -- based on the comment to the OP with the Z06 Stage 3? Will it fit wit the Level 2 Aero??
#79
#80
Which colors are you referring to? and yes the low profile bracket will fit
