Analog Speedo Replacement from mph to kmh: Is this complicated?
FYI, in the countries we live and where we want to travel, we are not able to get the car until mid next year, and we use C5-C6 and now will have a C7 (and for this C7, we are waiting since 2011 and declined purchasing many other cars). So this whole process is a little bit convoluted actually. A USA car will be shipped to Canada, then will be shipped to Europe. But you see, even though we do not like the "units", we do love the car
We will also be getting the car without a factory warranty, but we will purchase external warranty.
M
Moderator
No.. You are absolutely incorrect.. See the photo below... See the arrow on the left side. That speedometer on the left is the analog gauge she is referring to and it is not a whole unit. It is infact a separate gauge with a mechanical needle and does not change from miles per hour to kilometers. s is not part of the LCD instrument cluster nor are the temp and fuel gauges on the right side.
Received 3,290 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Where do you live? I travel to Europe extensively on business as I work for a large British company. A C7 will get a LOT of attention there.
Mostly will be in Germany & Italy. But in the countries we will be travelling to (and have travelled to before), any car which is not a Yugo gets attention!
M
Are these separate units or is this one integrated unit? When doing the replacement, will they just be removing the analog speedo or will they replace the whole 3-part panel?
Regardless, we are a bit worried about rattling, but GM technician here said it was an easy process in C6.
M
M
M
M
The dash has so many fasteners and screws that rattles should absolutely not be an issue. I will point out that the C7 dash and gauge cluster removal process is nothing like the C6 which was in fact easy. While removing the dash panel is fairly tedious, it's not complicated however it is much more time consuming and complex than the same process in the C6. I removed my dash panel on my C7 when I swapped in the carbon fiber FAY option one and did it myself. I have no rattles what so ever and like I said, there are so many fasteners that it would be next to impossible for it to rattle. As such, I'd say you have nothing to worry about.
That said, if you didn't order your car with the carbon fiber dash and would like to add that on, you can get it for about $550 landed from Bob at Fitchner Chevrolet and have it installed as part of the gauge swap. Since the dash will already be off the car, the cost difference to move the buttons and control stuff over should be negligible.
It's funny you mention that. When looking for that picture, I did see one image of the display with the KPH on it but it also had MPH illuminated. It was mentioned that there was a different speedometer that went up to 330 in the Canadian version of the car as shown in a video posted previously. I guess I should have worded my post differently since the max speed doesn't actually change on that mechanical gauge which would limit the max displayed speed on that gauge to 124MPH.
The Speedometer is a separate component from the center LCD display.
Thanks for carbon fiber dash option... but we do not like carbon fiber much.
Tomorrow we will order our C7 Convertible, and hopefully drive it in 2 months. And get a Z06 Convertible when it comes out.
This forum has been great help.
M
Metric & English Displays -- Corvette C7
My C7 coupe is an export version built for the Latin American and Caribbean market, and I'm told that the Canadian version, for purposes of this discussion, is the same.
Like all C7s, you can go into "Settings" and change the "Units" so that the DIC displays in "Metric" or in "English".
As you can see in the two photos below, shifting between the two settings changes all gauges (including odometer and digital speed read-outs) except the tach, of course, and the two far right gauges, which in my car, do not display any specific unit measurement.
And, the only change to the speedometer is the notation above the "30" from "MPH" to "km/h". All increments between "0" and "330" remain the same -- which is a little farfetched when in "MPH".
Vette is slang for Corvette, so people refer to any Corvette as a Vette, regardless of year, kind of top, etc. Vert is slang for a convertible. I've never, ever, see the spelling verte for anything.
And while we're on the subject, Vet is slang for an animal doctor or a military veteran (and maybe other things) but not a Corvette.
Hello All,
We are about to get a USA specs Verte (to be driven in EU). We are planning on replacing the Analog Speedo with a metric one.
Dealer said it is doable.
We do not want to introduce additional noises/rattling, etc. Is this a complicated process? Anyone experienced with such a replacement?
Thanks,
M
Thanks,
M
This video shows the km/h speedo. Thought it might help. And also I think they make them like that for specific markets.
#33
[QUOTE=alaincayman;1586790832]My C7 coupe is an export version built for the Latin American and Caribbean market, and I'm told that the Canadian version, for purposes of this discussion, is the same.
The C7 for all world markets except the USA, comes with the same DIC as mine (above two photos), configurable in "Metric" or in "English". You'll notice that the two gauges on the right, unlike the USA version, do not display any unit measurements.
#38
100% ... -> NO! They can use the createur de malheur cars from Renooolt, Pissjoe or Citrooon.
But i live in Germany, and i have a import C7Z06 no verte or vette. Same problem, the left speedometer ends at 220. So i´m looking for somebody who have the same problem and he change the Unit. Thanks Jan
