Why does GM limit the top speed on the C7?
At 6:15 in this video the K&N rep said GM has a speed limiter on the Vette, that's why this car only did 190MPH.
Anyone know if this is true?
Only reason I could think of is because of Tire ratings.
He also said the K&N filter will add up to 20HP, not sure if I believe that.
Received 4,684 Likes
Just a slick piece of advertising.
I don't think the car is electronically limited by GM, I believe it is aerodynamically/gearing limited. I believe top speed is in 5th gear (at or near redline), 6th and 7th are too tall. The car will NOT maintain top speed in 6th or 7th.
Jimmy
Jimmy
Obviously....nor does a "top speed" run mean anything on a dyno.
This thread is about the C7 being ELECTRONICALLY limited to 190MPH top speed (which the K&N guy claims), which is FLAT WRONG. In the REAL world, there IS DRAG, and the C7 will NOT do it's top speed in 7th gear as it is on the video. If you shifted from 5th at 190MPH (at or near redline) to 7th, the speed would drop like a rock because of DRAG. In the real world, I bet a C7 wouldn't maintain 170MPH in 7th gear, the ratio is TOO tall, drag is TOO high, and HP is NOT high enough.
And the up to 20 horsepower claim by K&N is laughable. At the max claim (20HP), the car is gaining 4.4% horsepower with an AIR FILTER change???? What material is the original filter made of....steel?
Jimmy
Jimmy
If they can do several tests with two identical cars with identical weight drivers, one car with a K&N filter one without, and document all the 0-60 and 1/4 mile runs and if the car with the K&N is faster on more than 70% of the runs, then I might THINK about getting a K&N filter.
Then, even at that, they'd have to swap the filter out of car 1 and put it in car 2 and do run same tests to try to rule out whether one motor was simply faster than the other from the day it was built at the factory.
Most likely so some idiot doesn't kill themselves by the tires flying apart on a dyno or on jackstands trying to get a picture of the dash at 250mph.
The car cannot go that fast but you could get the tires spinning that fast without a limiter on jackstands/dyno which I bet would end badly for everyone involved.
So the speed is limited electronically in addition to drag limited so the rear tires stay in 1 piece.
If it's really so easy to add 15-20hp without any adverse side effects whatsoever, then ask yourself why GM didn't make K&N air filters original equipment.
Received 3,289 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Two words come to mind reading K&N's claims: Snake Oil.
Dyno Testing the 2014 Chevrolet Corvette Stingray Z51! The J-Turn Ep. 16 - YouTube
