Infotainment System - Radio Button
Has anyone had the issue of the actual radio buttons (Home button, Radio button, etc) not working? The touch screen works fine, but the physical buttons are not working.
I did a search and found a link, but the OP did not indicate if he was able to correct the problem.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,812 Likes
2015 C7 of the Year Finalist
Just try the reset. Easy to do and can't hurt anything.
Elmer
Elmer
CF "Young" Senior Member
I had this happen once to me on my drive home from Bowling Green. I forget most of the detail, just know that after I shut off / started the car back up again everything worked fine.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Hasn't been an issue for me (VIN 11822 w/5K miles) but then again, I've always been good about pushing buttons
Apologies to hear about your radio button concerns. Any displeasure is understandable and we're here to help should you decide to get an official diagnosis at a GM dealer. You're more than welcome to contact us privately anytime to discuss this in greater detail.
William R.
Chevrolet Customer Care
Curious what the resolution was if original poster is around. Identical symptoms on my Nov 2013 built c7
Global reset (disc pos and neg and touch together) did not fix it.
