Do it your self Z51 oil change
After all the stories about to much oil......Do you put the car on ramps
to pull the two drain plugs, How hard is the oil filter to get off? What procedure do you guys do? What oil filter is needed and what type tool to take it off....band wrench of oil filter socket...Thanks
If you are worried about the overflow, just get it to where you should take a reading acc to manual, and then use a turkey blaster and take out enuf so it reads midway in the hash marks (or even lower), no need to go nuclear with a full change if oil is still good....
I don't remember struggling with the oil filter, but I have just about every device to remove them, so it's usually not a struggle on any of my vehicles.
(My car is a Z51, not sure if the base model oil filter is different)
If you don't know about it, member Theta is assembling a volume of DIY How To's from the service manual. They are located in the C7 Tech Forum Sticky section. Here's the Z51 oil change procedure:
http://forums.corvetteforum.com/c7-t...ump-specs.html
Hastings,NapaGold/Wix,Mobil1,Bosch,K&N,Royal Purple,even purolater>fram.
Not trying start anything just putting it out there for future reference.
More than just my $.02
My dealer will only do the free change at the one year point or 5000 miles. I may not put 5000 miles on it in a year and don’t like letting oil stay in the car that long. Don
With all this overfill going on, unless you trust your dealer, I would do it myself. It is not hard at all. If it is a Z51 don't put over 9.5 quarts back in. Good luck.
Glen, how do you use a turkey baster to get oil out? Through the dipstick tube? Does it seat well enough to pull it out?
You will need to drain from the bottom using the plug at the base of the oil tank tube. I don't know exactly which of the 2 that is off the top of my head.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,818 Likes
2015 C7 of the Year Finalist
Steering wheel controls on right of wheel.
Press down arrow until you display "Oil Life"
Press "Right" arrow and Press Ok
Elmer
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
http://netwelding.com/Changing_Oil.pdf
Details on lifting replacing filter and drain plugs etc. Comments about filling 1/2 quart low to avoid overfill
This is a PDF with details of my oil change in a Z51:
I do one more thing which may be unneccesary. I fill the new oil filter with oil before installing. Maybe this eliminates a split second when the oil line is sucking air from an empty filter.
I have also found that big pair of channel lock pliers works to remove the old filter if you don't have the special oil filter cap wrench.
