Where to mount EZ Pass sensor?
Does anyone have a solution to mounting EZ Pass sensor boxes. Seems they block the view [or the passenger's view] or, if you mount it at the bottom of the windshield, the toll reader doesn't find it.
I called EZ Pass last week to register the new Vette, and all they wanted was the plate number. I don't think we need the sensor anymore. But I'm going to double check that when I get the new plates from the dealer.
Received 1,863 Likes
2020 C8 of the Year Finalist - Unmodified
I keep it in the glove box until needed. I am not, however driving through them on a daily, or even weekly basis.
Only car I actually have it mounted on the windshield is my company car as I'm often driving around Philly, and NJ, NY and it's non stop there.
I keep the Vette out of there!!!
They have one that mounts on the front license plate bracket (top 2 screw holes) and it comes with one-way screws (or hide it behind the grille). You'll need a front license plate bracket mounted to the car though and many don't like it.
https://www.google.com/search?q=ez+p...=1920&bih=1117
I hope this gets clarified.
"Is there a location other than my vehicle’s windshield where I may affix my E-ZPass® transponder?
No. Unless your E-ZPass® is installed exactly as shown in the E-ZPass® Customer GuideBook, it may not be "read" by the E-ZPass® antenna. Placing the transponder on the sun visor, the rear-view mirror, the dashboard, the seat, or in your hand may work occasionally but will not work consistently. Install the transponder exactly as shown in the instructions on page 3. Transponders installed incorrectly or not at all can result in toll-evasion violations, administrative fees or delays at the toll booth. In addition, customers subscribing to discount plans may be charged full fare for these transactions if their transponders are not installed properly, or are not installed at all."
I keep mine in the glove box and pull it out when needed, and it's never not been read when I set it on the dash.
Here in Florida we now have EZPass RFID stickers that are much smaller and easier to hide behind the rear view mirror. Maybe check to see if your state offers them now too?
I ordered mine a few months ago and was pleased to see they now have much smaller ones than I used to have. It mounts directly behind the rear view mirror and does not obstruct anyone's view at all. In fact, if I didn't see it from the outside when parked, I wouldn't even know it was there.
In New York they send Velcro strips that allow you to detach it when you are not going to use it for a while so all that is seen is the very small Velcro strip that sticks to the windshield....again behind the rear view mirror.
While mine is mounted just below rear view mirror and is a none issue I also painted it black and used black Velcro to mount it. Works fine and almost invisible from outside the car versus seeing an ugly white square.
I appreciate all the replies. First I am going to get the new smaller unit, which they won't mail to me as an exchange. I have to drive to NY to pick it up.
I will see if the smaller view blockage, centered under the mirror, is objectionable.
If so, I'll try it at the front of the clear roof. I may have a problem there, as I put a sheet of carbon fibre vinyl as a stick on coating on the clear roof to cut down on sun. Works great, but may interfere with the signal to the sensor.
Always something.
Always something.
Received 2,221 Likes
When I got my EZPass in PA they had a unit that mounted to front license plate. This is where I mounted it on my C6. I assume there is a similar place on a C7. It reads right thru the plastic hood and is more powerful than the windshield unit.
Was that their recommendation since we have no front plate in PA, or your idea?
Do you think the difference in conductivity between fiberglass and carbon fiber will make some mounting options on the C6 unusable on the C7? We were able to put radio antennas inside the fuselages of fiberglass model sailplanes, but had to put them outside on carbon fiber models. The carbon fiber would block the low power RF signals.
