Constraints - July 24
Moderator
RPO....Description...................... ..........Availability
FAY....Carbon Fiber Dash..............................40%
Z51....Performance Package............................55%
C2Q....Dual Roof Package (Body Color and Transparent)..0%
C2Z....Visible Carbon Fiber Roof......................20%
C2M....Dual Roof Package (Visible CF and Transparent)..0%
G1H....Daytona Sunrise Orange Metallic.................0%
EFY....Body Color Vents................................0%
CFZ....Carbon Fiber Ground Effects Package.............0%
SDN....Black/Silver Stem Valve Package.................0%
CFA....Standard roof (painted)........................35%
QCC....Black Machined Wheels...........................0%
E57....Carbon Fiber Tonneau Inserts....................0%
As member Woody pointed out, these are for build week of 8-25
Last edited by Zymurgy; 07-25-2014 at 12:33 PM. Reason: Added build week info - thanks Woody!
Those are for build week 8-25.
Moderator
If it's a hassle to get a hold of the dealer, then they're not doing their job. I was always able to talk to my salesman throughout my C7 journey. He even got status updates for me while he was on a week long vacation.
For those "in the know". Please "splain it to me Lucy". I'm ignant and admit I don't fully understand constraints. If I place my order for my "ideal" Corvette and during the "expected production week" there are constraints on one or many of the optional items I included on my order, will the car production be placed on "hold" waiting for the constrained items? Or will the car just be produced without them? If I choose not to build (I'm assuming my dealer will be giving me the option) will they (GM) cancel the order or, just keep the TPW in limbo until the "suppliers" can ship the constrained items. I'm sorry if this issue has been covered in other threads, I've just never seen this question answered.
once you are at and past status 2000, you are fine and constraints should not affect your car.
Almost fine. Constraints effect whether the order will be accepted (2000) is true but as others besides myself have experienced, an order may not be built for sometime because of the item constrained.
Now we come to a guessing point, because the dealer does not know if the order is not being built because of the constrained item, or another item, or just as a matter of course in the production process. But as far as I can recall in these times the order will not be built until all the parts are there. In the twentieth century maybe but not in the twenty-first.
Laborsmith
Laborsmith
Second, every other week (currently, sometimes it is every week,) GM has a consensus, where they match orders with production for a week approximately 5-6 weeks away. At this point, they try to match a dealers share of his yearly quota of vettes, with the orders he has waiting to be filled. GM will tell the dealer how many coupe and convertible orders he can place that week, and what constrained options they can have.
Constraints don't mean that option won't be produced. It means there are limits on the option. Currently, Z51s are constrained at 55%. This just means for every 100 vettes produced during that cycle, only 55 can have the Z51 package. Now if you start combining constrained options, then you can effectively halt production of your car. Say you want a visible CF roof with your Z51. Since that option is at 20%, then of the 55 Z51s out of 100, only 20% or 11 cars will have both options. Throw in some other constrained options, and you reach an almost zero probability of getting your order accepted. That's why dealers will frequently ask if you want to drop an option, because they know that they can get an order without that particular option allocated.
Once the dealer has matched the orders with GM's allocations, those orders advance to status 2000, which is "Order accepted by GM." Again, constraints only apply during the allocation process. Once an order is accepted and goes to 2000 and beyond, constraints will have no affect on the order being produced, although it may affect the timing, if a needed part is in short supply.
Also realize that a small dealer may only get 1 car allocated per month, assuming his yearly allotment is 12 cars or less. Therefore, any order with a constraint will have a tough time getting filled, while one of the mega-vette dealers might get 80-100 cars in the period, making much easier to get cars with constrained items.
First, in the GM internal system, there are over 20 status codes, that describe where your car is in the order process. The first is 1100, which basically means your dealer has managed to type a valid order into the computer. At this point, there is no valid guarantee that your car will ever be built. There are still 2014 customers with 1100 status orders which never got accepted.
But there is one other curve ball to the allocation percentage. Using the Z51 option as a guide it's true that for the production period the consensus is for (can be 1 or 2 weeks) only 55% of the total will be Z51's. That does not mean at the dealership level that they will be able to order 55% of their allocation as Z51's. GM allocates constrained items based on previous year sales just like it does the total number of cars. For example, last week Kerbeck had 88 allocation slots, 75 of them were for Z51's while the global Z51 constraint was 55%. That means a lot of small dealers with 2, 3, or 4 allocation slots for that week may not get any Z51 allocation.
So basically, knowing the global number is interesting but somewhat meaningless without knowing your dealer's actual allocation allotment, which most will never share with you.
Great answers on the issue of constraints. Thanks. I have an additional question however. I have read in this forum several times that the Z51 is/or has been on constraint. What is the problem with the Z51 (who is the supplier? and where is supplier located?) Z51 constraint was already a big issue for the 14 Vette (I know because our initial order (RJZJCP) never made it to production because of this constraint last Spring. Now have a 15 Vert Z51 2LT on order (RWWW4R Florida ) (status 3000 - our dealer says there are no constraints, but I keep reading forum and have seen some people mentioning of Z51 constraint again. Can someone PLEASE explain the Z 51 constraint issue. We surely do not want to wait another 8.5 months to get our 15 Vette. Thank you Heidemarie
Correct except consensus is every other week and dealer ordering is usually every week. The last several months of the 2014MY the consensus and ordering were effectively combined, probably because there continued to be so many customer (retail sold) orders. Consensus is for all Chevrolet vehicles, not just the Corvette.
It is during consensus that some dealers get additional allocations; this is most markedly noticed toward the end of a model year; recall how various forum dealers were posting they had received additional allocations. Some allocations are redistributed because a dealer declined to use an allocation and in the case of the C7 some were redistributed because a dealer was not eligible. Remember, so far since inception every Chevrolet dealership gets allocated at least one Corvette every model year even those few hundred dealers who have never ordered a Corvette. I expect the time is near that only dealers who meet the minimum (tools, trained tech and trained salesperson) standard will start the model year with any Corvette allocations. Very near.
Laborsmith
Laborsmith
The issue is there are a number of high priced components used to make a Z51 that suppliers can only make a limited number of a year. Altough it would seem that if there were no constraints 90% of the cars sold would be Z51's but history proves that to be wrong. The sweet spot, historically is under 50%, which is what GM contracted with it's suppliers for last year. What caught GM off guard (the why's have been argued at length so I won't go there) was an 85% take rate in the first 2 months of ordering back in 2014 basically depleting 1/2 of their projected production of Z51's. They had to heavily constrain Z51's starting last October or they would have severely limited their total year sales. Over the winter they not only renegotiated but also invested millions of dollars with their suppliers to increase their capacity to produce certain parts. We are not privy to which exact parts but me and many others suspect the ediff as the primary culprit as it's probably the most difficult to increase production on and cannot be multi-sourced.
The belief was they would be all set to go forward with no constraints in 2015 and let the market set the level but I suspect the first week of ordering again showed a very high take rate because there is the perception that Z51's are rare and hard to get, which is ridiculous because over 17,000 Z51's were built in 2014. Rather than wait they constrained the Z51's to a level they know they can support AND should actually meet market demand (projected to be ~60% of total sales over the course of the year) hence the 55% constraint since the 2nd consensus.
The second, the gearing for the Z51 likely means not as good fuel mileage as the non-Z51 and GM needs a certain mix for CAFE.
Laborsmith
3000 means your order will be produced. Constraint is what keeps orders from advancing past 1100.
