Best way to remove 2 way tape residue ?
What's the best way to remove double sided tape residue ? I am replacing the small weatherstrip behind the back glass that runs along the back of the roof . Thanks in advance .....
Absolutely not, much stronger, can discolor some paints and plastic....
From their website:
General Purpose Adhesive Remover MAX VOC 20%
CAUTION: Always test on an inconspicuous area first, as every hard surface is different. Damages many plastics, worn vinyl floors, some automotive paints, and some carpets.
From their website:
Received 4,499 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Received 19,232 Likes
'20-'21-'22-'23-'24
Goof Off or Goo Gone, both work very well to take off adhesive.
Sanford thinner for rubber cement. Remove the tape residue with a rag dipped in the thinner which has a high flash point, so it evaporates quickly. Way less messy than Goo Gone.
Acetone will work on original paint (clear coat ), as well. I've used it for at least two decades. It will take off any adhesive residue and leave a perfectly clean surface for whatever you need to apply.
I have used it on repainted areas w/o any problem, but would check just to make sure your paint guy is as good as mine.
E-Ray, 3LZ, ZER, LIFT
Received 9,606 Likes
I have goo gone , goof off , mineral spirits and wd 40 . I don't have an eye dropper . I am going to try the wd 40 first on a rag .
Thanks for all the replys .....
Well , I did it . Very messy job . I used the wd 40 . Just sprayed it on and kept rubbing and rubbing . Took me an hour but it's done . Looks good again and I am glad it's over ....
