2015-2017 C7 Corvette Z06 Clear Tail Lights In Stock @ CULTRAG Performance!
Premium Supporting Vendor
Greetings Customers & Friends,
The tail lights are $545.99 for the set. GM charges $50 per tail light as a core charge so the set is $689.99 to purchase. If you ship back to me your original tail lights in the boxes that the Z06 tail lights are shipped in we will give you the $100 back.
Click below to order on our website!
http://www.cultragfactoryparts.com/c...z06taillights/
Thank you!
Gene.
Thank you!
Gene.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
A question for you, Gene: Since the Z06's lenses are clear, I assume that the LEDs / bulbs that produce the lighting (for tail and brake lights) are red. Is the same true for the Stingray's bulbs / LEDs? I'd have thought that on the Stingray the LEDs / bulbs would be white; if that's the case, we'd have to switch to red ones if installing the clear Z06 lenses. Am I missing something here?
For instance the bulb can be clear and still produce a red light. That is the case with these lights pretty much. I think they're lined with small led bulbs which are clear but when lit appear red. That's how they're able to pull off the design with no red reflector in the lamps.
LED bulbs don't have to be the color of the light that they produce.
The Z06 lights will already have the proper led's inside. I'm pretty sure these lights are sealed assemblies, not meant to be opened. They're not simply different colored lenses. You would simply remove the stock Stingray tails, then install the Z06 tails.
Received 2,673 Likes
2018 C5 of Year Finalist
Curious why GM would charge for cores? Do the recycle used Stingray tail lights and then resell them as new replacements?
I don't know the answer to this question. GM even has a core on the base Stingray tail lights. In the last 1-2 years GM has implemented a lot of core charges on a lot of different items.
The tail lights are easy swap, just need to loosen up the rear bumper.
I tinted mine as I installed the rear spoiler'
I just got mine all the way out here in Dubai; thanks Gene! I'll post pictures after I install them on my SGM
