Z51 Stingray vs. Z06....differences?
#41
The Z in the name will impress most people who don't know much about the C7. It will also impress people on this forum!
The Z51 is just an option on the base. Worth every penny to many.
If you want the Z06, I suggest most people go to school somewhere before driving.
#43
Flex182 (05-23-2016)
#44
The Consigliere
Received 5,445 Likes
Some of the Z06 differences:
- bigger brake rotors and brake calipers
- optional carbon ceramic brakes (with even larger rotors and calipers; Z07 package)
- wider wheels/tires
- larger hood vent
- larger fender vents
- larger and exposed rear brake vents
- different front grille
- wider fenders (to fit the wider wheels/tires)
- obviously the hp/tq difference with the supercharger system
- different heads, intake, oil pcv system, camshaft, forged pistons and crank (i think the block is the same?)
- different exhaust
- carbon fiber torque tube
- larger heat exchangers/coolers for transmission and rear diff; different air intakes for those exchangers
- slightly different cockpit appointments, but same overall style/layout
- different gearing
- different suspension set-up (and Z07 is different yet from the standard Z06)
- different PTM system and mag shock calibration
- different fuel mileage
Similar smile inducing fun. Go get one (of either model); they're a blast.
- larger hood vent
- different exhaust
- different gearing
#45
GM will do whatever possible to sell more cars, so a subtle rearrangement of the price sheet to benefit themselves comes as no surprise. However they can't fool all of the people all of the time.
However, in stark contrast, there is absolutely no debate needed, as the Z06 is a complete and separate model of its own.
#46
Or do you mean in build and price where it offers the 3 trim levels with the option to add the "Z51 Performance Package"?
Did your car come with a Stingray on the sides? Or did you buy yourself some Z51 emblems on eBay?
#47
You mean on the website, after I have to click on Stingray instead of the only other option which is Z06?
#49
It is up to debate as to whether the Z51 is an option or a true model of its own. GM didn't add anything substantial as part of the Z51 with the C7 that didn't already exist with the C6 Z51 option.
#51
Not sure??
LuisZ51 (06-05-2019)
#53
Or the 2015 Ordering Guide, which lists only three Corvette models: Coupe, Convertible, and Z06.
http://www.corvetteblogger.com/docs/...rder-Guide.pdf
Here's page 104, which shows the Z51 as just another RPO code, like floor mats or the PDR.
Instead of being insulting, do you have any evidence to refute the two items above?
#54
Really?
Both of the posts above are irrefutable.
Personally, I couldn't load my Vette with many options like the Z51. It's just a slippery slope to get the improved model, the Z06 for just 79K.
The Z51 option turned me off because I am too impatient to deall with waiting for the oil temperature to be right. I really wanted the ELSD and dry sump, but there were too many issues with those. I just want something that works. The sway bars I want and will add those very cheaply. I also didn't want to pay extra for magnetic ride.
That being said, if you want to track your car or just want an even more awesome Stingray, the Z51 option is a fantastic value. I would still rather use different wheels/tires on the track. But wow, what a value with the differential cooler, dry sump, ELSD, exhaust and bigger brakes.
#55
I don't think there is any C7 Z06 that GM states will reach 200mph. The do cite the Z07 package with a top speed of 190mph because of the increased downforce. No Corvettes have any speed limiters.
#57
I'm not to well versed in Vette's yet and was curious what are the obvious differences b/w the two cars?
Both have aluminum frames now?
I understand the z06 body is slightly wider and I am familiar with both engines but I was curious what are the diff. in the details are?
2014 z51 didn't have 1.
#58
First few posts glorified about how z06 is track built, but there are many reports that it overheats. I had c6z06 and that thing was surely track ready out of the box, but it was hard to handle. Z51 has decent suspension, and good amount of hp, thus i think its quite good track car. 650hp/tq z06 seems like waaaay too much for the track. If u look at most race cars they might have higher hp number, but def less tq. Im sure with proper semislicks or slicks it will be fast, but on street tires i think z51 could give it a run for its money due to the fact that z06 is just too hard to handle.
#59
Really?
#60
I dunno??
Here's a link from GM getting 195MPH out of the new ZO6. Maybe with enough road in Mexico, you can hit 200MPH? The 2016 CTS is claiming 200MPH! Check it out! I thought a tuner would read the Top speed 186MPH for instants on the C6 which can be turned off?? That's what I read anyway's??
