Old 03-05-2015, 06:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Print Wikipost
C7 grill swap for Z06 grill
Old 02-14-2016, 11:21 AM
  #41
joeybsyc
joeybsyc's Avatar
Originally Posted by Mdm23
It changes the look but not like the Z06 grille does. The base grille just doesn't fit the styling of the car imo.
Retainer blacked out:
Z06 Grille and Splitter:
No contest in my opinion.
Agreed 100%. All the blackout and tape in the world isn't going to make the stock Stingray grille look as good as the Z06 one. They should offer it as a factory option, or just get rid of the Stingray one all together.
Old 02-14-2016, 11:31 AM
  #42
360Lemans
360Lemans's Avatar
Z06 Grill with Z06 Front spoiler
Old 02-15-2016, 07:16 PM
  #43
capecodvette
capecodvette's Avatar
Originally Posted by C7Joy
Does the aero license plate frame work with the Z06 style grille?
The standard grill aero plate DOES NOT work, without modifications. EBay is a good place to find the correct Z06 front grill aero license plate frame.
Old 02-16-2016, 11:32 AM
  #44
steve miller
Support Corvetteforum!
steve miller's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Huge difference
Old 02-17-2016, 12:08 AM
  #45
brandont619
brandont619's Avatar
Originally Posted by steve miller
Huge difference
Is that the stage 1 OEM Z06 splitter? If so, did you have it painted carbon flash?
I'm looking for a professional shop to sand mine down and paint it... Can you provide more info on this please!?
Old 02-17-2016, 09:38 AM
  #46
steve miller
Performance Corvettes....forum vendor takes the oem part, sands it and paints it for 249.00 plus shipping...Johnny is a really good guy....I destroyed my expensive and beautiful RPI front splitter...I didn't want to spend big bucks on something that was gonna take a beating and then I found Johnnys ad....not on the Forum but on amazon...I call them disposable splitters.....I just ordered my 3rd one......I only back into parking spaces now...I learn slowly...and yes it is CF metallic
Old 02-17-2016, 09:51 AM
  #47
Kracka
Kracka's Avatar
Received 5,675 Likes on 2,897 Posts
I love the new look. The job wasn't hard, just a little tedious when you get to all the little plastic tabs that hold the grill to the bumper cover. I did take the opportunity to vacuum/blow out all the trapped bugs! A second send of hands was helpful so thank you to my buddy Turk/T6/TheDogfather...whatever he goes by on here
Old 05-21-2016, 09:15 AM
  #48
RidgebackKing
RidgebackKing's Avatar
Just finished swapping my new Z06 grille on my AW C7 Z51 and it looks gorgeous. Now that it's on though, I'm wondering about the brake duct openings. Without the "screen" in front, seems like it would be easy for bigger items to now get sucked in. Is this something I need to worry about?
Old 05-21-2016, 09:23 AM
  #49
ssidekickbp
ssidekickbp's Avatar
Received 1,005 Likes on 328 Posts
Ordered mine from Gene at Cultrag. You can't beat the look. So much better over stock. The blackout mod/ newer blacked out grill is NO comparison to the Z06 Grill.
Old 05-21-2016, 09:52 AM
  #50
SharkGrayStingray
SharkGrayStingray's Avatar
Nothing to worry about. These are brake cooling ducts, not intake ducts...
Old 05-22-2016, 11:36 AM
  #51
allpork
allpork's Avatar
I have a 2014 Non-Z51 A6 and am planning to order the Z06 Grille and Brake Duct Kit.
Is it easier to do the Grille Mod with the front wheels on the ground or perhaps with them raised?
For the Non-Z51s, do the Brake Ducts get mounted while the bumper is off or after it is reinstalled? Do the ducts bolt right up or is there some trimming involved?
Old 05-22-2016, 12:02 PM
  #52
eboggs_jkvl
Moderator/Tech Contributor
eboggs_jkvl's Avatar
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,810 Likes on 2,058 Posts
2015 C7 of the Year Finalist
Up on a ramp is good to get at all the bolts to remove the nose. With the nose off, you can put on the ducts very easily, especially up on the ramps.
I don't know about the trimming as I have the Z51 and it came with the ducts.
Elmer
Old 05-22-2016, 08:46 PM
  #53
allpork
allpork's Avatar
Elmer
Thank You.
Old 05-23-2016, 07:05 AM
  #54
WKMCD
WKMCD's Avatar
Did the swap this weekend on mine. Easy job. I took the opportunity to fix some scapes on the splitter and repaint it while it was off.
Old 05-23-2016, 08:18 AM
  #55
Big Lebowski
Big Lebowski's Avatar
Received 3,966 Likes on 1,664 Posts
I loved the Z06 grill too. I got my grill free...with my $87k Z06.
Old 05-23-2016, 09:33 AM
  #56
chrsschb
chrsschb's Avatar
Did the swap this weekend but the tabs next to the headlights on my car would not let loose without a ton of leverage. One side ended up dropping (after I got it loose I had it propped up to stop it from falling onto the floor) and it caused too much tension and creased the other side against the hood (pinching and peeling the paint on the edge). I'm pretty pissed about it but I guess that's a lesson learned. The spot is about 1/4 of an inch long so will touch it up and carry on.
daleong (05-23-2016)
Old 05-23-2016, 10:47 AM
  #57
RidgebackKing
Process took me about 74 minutes.
The following 2 users liked this post by RidgebackKing:
Is2scooby (01-14-2017), RapidC84B (11-27-2017)
To C7 grill swap for Z06 grill
Old 05-23-2016, 12:13 PM
  #58
hisvett
hisvett's Avatar
St. Jude Donor '14-'15
Issues with the two clamps can all be avoided with a trip down to the local AutoZone Parts dealer and buy a long 1/4" drive extension and just loosen the the bolts to remove and then re-tighten after assemble when it's all re-aligned again. I had no problem; no prying, hammering or pushing into place.
Old 11-20-2017, 05:19 PM
  #59
G-ForceJunkie
G-ForceJunkie's Avatar
Originally Posted by C7_Z06
Yes it does.
Originally Posted by Gene Culley
Just to let you know the standard aero panel does not fit the Z06 grille. You'll either need a Z06 license plate bracket or a Z06 aero panel and either will need the new retainers. I've taken some photos of the Z06 aero plate, Z06 bracket and Z06 retainers. If anyone is interested in any of these items contact us!
All the information in parts look-ups I can find shows the Z06 and the standard C7 aero panel as the same part number, but I don't want to doubt Gene's experience here. Can anyone re-confirm that the base C7 aero panel will fit onto the Z06 grille? Thanks!
Old 11-20-2017, 06:40 PM
  #60
SharkGrayStingray
The base aero plate will NOT fit the Z06 grille.
G-ForceJunkie (11-20-2017)
Quick Reply: C7 grill swap for Z06 grill
