Shifting hard when cold
Old Feb 13, 2015 | 08:57 AM
Blue2015's Avatar
Blue2015
Default Shifting hard when cold
I've had my car less than 2 weeks. Just passed the 500 mile mark 2 days ago.
2015 Coupe, Manual transmission, Z51.
In any case...
I've noticed that shifting gears is somewhat difficult until the car gets warmed up. After that, the shifts are smooth and easy.
I'm not necessarily surprised or concerned by this. But, I'd like to know if this is typical. (I don't remember the transmission in my C6 behaving this way.) What have you guys experienced with this? Are shifts always difficult when car / transmission is cold? Do cold shifts get easier over time?
Old Feb 13, 2015 | 09:00 AM
theanswriz42's Avatar
theanswriz42
Cruise-In 8 & 10 Veteran
St. Jude Donor '08, '15
There are a lot of threads on this. It's normal.
Old Feb 13, 2015 | 09:52 AM
LEJ ZO6's Avatar
LEJ ZO6
Yes, normal.
Just take it easy and don't force anything until the trans. temp comes up to normal operating temperature.
Old Feb 13, 2015 | 09:58 AM
dvilin's Avatar
dvilin
by
Originally Posted by LEJ ZO6
Yes, normal.
Old Feb 13, 2015 | 10:04 AM
cheapthrills's Avatar
cheapthrills
I'm in FL and have noticed this as well, must be really noticeable when it's 0 outside.
Old Feb 13, 2015 | 04:25 PM
iclick's Avatar
iclick
The transmission "learns" as you drive and the dealer claims it takes about 500 miles to adapt. That's just what the world needs, a thinking slushbox. Mine in S. LA has about 250 mi. on it now (one week) and it still does it, just not as bad as when new(er). There are threads about TSBs that address a chronic condition, basically resetting the EPROM (or whatever) to default and starting over with the adaptation process again.
Old Feb 13, 2015 | 04:53 PM
SFZX's Avatar
SFZX
I've had mine for 6000 miles and it still is the same but gets pretty smooth when its warmed up. Be sure the clutch is being pushed all the way to the floor. Sometimes I catch myself getting a little lazy here and it gets a bit notchy. On my next shift I think about it and its much smoother.
Old Feb 13, 2015 | 05:13 PM
mksz51's Avatar
mksz51
You're in the wrong room - we're talking manual transmissions here. Automatics are the first door on the left.
Old Feb 13, 2015 | 06:36 PM
Mike's LS3's Avatar
Mike's LS3
Nothing to learn, it's a manual. After putting a few thousand miles on it the synchros should mesh better. Should get better with mileage.
Old Feb 13, 2015 | 06:57 PM
USMCVETC7's Avatar
USMCVETC7
I have about 2,000 miles on mine and it still does it. I realize that many owners experience this, however that is no reason to say it is normal. It should not do it, cold or warm. But it's easy to work around and I'm somewhat used to it.
Old Feb 13, 2015 | 07:46 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
17.3K on mine and it's done it since Day One.
No big whoop.....
Old Feb 13, 2015 | 08:43 PM
stevedun's Avatar
stevedun
Cruise-In 8-9-10-12 Veteran
Manuals have have always been harder to shift when cold. Not just the Vette. Every car with a manual will be this way.
Old Feb 13, 2015 | 09:30 PM
iclick's Avatar
iclick
Yep, just got up and moved over there.
Old Feb 13, 2015 | 09:54 PM
wayles's Avatar
wayles
Old Feb 15, 2015 | 10:53 AM
thrilled's Avatar
thrilled
I keep mine put away in The cold.I have driven it up til Christmas and have never noticed
Stiff shifts.I hardly shift easy.So maybe with my arm I just shift fast and firm.
Old Feb 15, 2015 | 11:03 AM
dovervold's Avatar
dovervold
That's how mine is, pretty stiff until the temps warm up. You don't want to be getting aggressive anyways until your oil temps climb...
Now if you want a real game changer, add a MGW shifter. Spendy but worth it. The shifts are so clean and fast it is really amazing. 2nd to 3rd is perfect every time. And now they have this trick flat blade retro look that is really cool!
Old Feb 15, 2015 | 11:06 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
In any case...
Agree, don’t recall my C6 6 speed being as “stiff” when cold. But then it is very cold this year! I just pull a little harder into 2nd. The other gears are fine and once warm all are at least as smooth as the C6.
I have found the cue ball size shift **** I installed 10 months ago is a help with the 1st to 2nd shift and when moving sideways to 5th, 6th and 7th.
Cue Ball Size Shift **** is a Help
To Shifting hard when cold
