Constraints - March 26 for TPW of May 15 (both Z06 and non-Z06)
Moderator
RPO............Description.............. ..................Availability
Z51............Performance Package............................50%
C2Q............Dual Roof Package (Body Color and Transparent)..0%
C2Z/C2M........Roof Panels ...................................30%
CFA............Standard roof (painted)........................45%
Z07............Z06 Performance package........................45%
CFZ - Z07......Carbon Fiber Ground Effects minus Z07 Perf Pkg.35%
&CFV...........Carbon Fiber Ground Effects....................15%
G8A............Velocity Yellow Tintcoat........................0%
Q6J............Spectra Gray Z06 Wheels.........................0%
Target Production Week of May 11, 2015 for both non-Z06 and Z06.
Velocity Yellow constraint is described as a Model Year Buildout Restriction. Most likely Velocity Yellow will not be available for Model Year 2016 and may not be available for the rest of 2015.
Roofs and Spectra Gray Wheels are described as Supplier Restriction.
Z51 and CFV are described as Material Restriction.
Z07 and CFZ-Z07 are described as Marketing Restriction
Standard top?
Have a friend who ordered a C7 more than a month+ ago. Dealer is telling him there is a constraint on the standard painted top so delivery uncertain. Really?? the standard top on constraints?? Makes no sense to me. They told him he could get a transparent top immediately.
Does this make sense to anybody?
Luckily I found someone on the board to trade tops with that was also getting their car the same week as me. If your friend wants a '15 I suggest you tell him to do what I did.
Moderator
CFA............Standard roof painted)........................45%
Clearly the standard roof is on constraint and has been for nearly the entire 2015 Model Year. Both the standard painted roof and the visible carbon fiber roof are both carbon fiber. Due to rapidly expanding use of carbon fiber, there is a global shortage of the raw materials used to make carbon fiber. This is not just impacting GM:
Carbon fibre shortage slows BMW i3 production
The Dawning of the Age of Carbon Fiber Meets an Obstacle
Yes, the dealer is being completely honest.
Ok then.....
So my vehicle is at 3000 and my TPW was pushed from 06 Apr to 11 May because there is no availability from supplier of Spectra RIMS. I can also see that there are constraints on my CFV and painted roof but apparently I have escaped those.
I just received word that I cannot change the order whatsoever because of its status.
So the question is ... Does the fact that I am already at 3000 mean it will be built or, if there is no Spectra availability, is it possible this order will never be filled?
Moderator
Constraints normally only impact you when going from 1100 to 2000. Once you hit 2000, you have already made it past constraints. Now, I suppose it is possible that some unexpected problem might cause your TPW to be delayed or possibly even worse. If I were you I'd be pushing your dealer to get to the bottom of this.
Moderator
I am actually getting my assistance right now from as close to the source as one can. I have been told that it was an unexpected supplier issue that caused me to be affected and there are no Spectra rims. I am going to guess this isn't a normal occurrence. So begs the question that if we are at 3000...does that guarantee production or can an unexpected supply shortage cause a constraint that will mean the order won't get filled?
I was told by my dealer (MacMulkin) last week, I had a TPW of 27 April.....it's a non-Z06. CRT 2LT with painted roof.
Not sure this info helps much....
So if I were looking for more information on my particular order, do you think Customer Service on chat would be able to address my constraint concerns or is there another avenue I should take? Thanks for your thoughts...after all of this waiting, it's hard to think about anything else!
I was given a TPW of 5-18 right out of the gate which was on March 21st. I also have the Spectra wheels, I am thinking the supplier has more wheels coming just a little later than needed. Glad mine got accepted with the wheels period.
Eric
Eric
AllFlash, at 3000 the unit will be built and price protected. Even if it goes to the next model year. This rarely happens; one could go whole model years with it not happening. But it can happen and has.
Disadvantage: a few more months of waiting.
Advantage: price protection and those improvements that occur from one model year to the next.
99.99+% of accepted orders are built in the correct model year and I suspect yours will.
The essential point is once accepted it will be built.
Laborsmith
Laborsmith
Laborsmith
Laborsmith
