C7 Procharger kits! | BEST pricing and FREE shipping! | JDP Motorsports
Old 04-01-2015, 05:40 PM
0JDP Tech
Former Vendor
JDP Tech's Avatar
Default C7 Procharger kits! | BEST pricing and FREE shipping! | JDP Motorsports
JDP Motorsports is proud to offer, use and install Procharger forced induction systems!
Building on a 20-year history of forced induction engineering and innovation, ProCharger is the first supercharger manufacturer to design and release a highly efficient air-to-air intercooled supercharger system for the C7 Corvette Stingray. With an original bracket design and belt-drive system unique to the C7 Stingray platform, ProCharger P-1SC-1 intercooled systems and tuner kits continue to lead the industry in OEM-style fit and finish, ease of installation, and reliable performance.
Our C7 Corvette Stingray HO Intercooled Systems with P-1SC-1 are supplied with proven tuning calibrations and a handheld programmer set for a 40% power gain over stock, on 7 psi of boost and pump gas. Higher boost levels and horsepower gains of up to 50% are possible with an Intercooled Tuner Kit and custom tuning, and even higher with modified motors. For hyper-custom racing builds, F-Series supercharger models up to the 10.5” volute
F-1X and F-2 can be installed without the need for additional brackets.
These ProCharger systems also give Corvette owners multiple options in both the performance and appearance arenas, with your choice of a vertical or horizontal-mounted intercooler, a supercharger air inlet with race-style filter or a factory air box interface, and either polished, satin, or black finish for the brackets and head unit.
ProCharger C7 Design Highlights
• 40% HP gain with P-1SC-1 on 7 psi, high quality pump gas
• Up to 50% HP gain with tuner kit, custom tuning
• Higher gains possible with modified motors
• OEM quality bolt-on design and finish
• First C7 supercharger system produced by a supercharger manufacturer
• Two air inlet options–OEM interface inlet or race air inlet
• Three supercharger and bracket finish options–Polished, Satin, or Black
• Largest intercooler options for the C7, with Vertical or Horizontal mounting
• Fastest installation out of our entire product offering
• Complete systems and tuner kits shipping since February 2014
• Handheld Tuner available
• Retains the factory brake cooling ducts
• No relocation of ABS, ABS lines or any factory parts
• Only three silicone hoses and one metal tube in the entire ic system
• Large 24" x 9" x 4.5" core size for both intercooler options
• High-flow, factory drop-in replacement air filter for standard inlet option
• Allows upgrade up to F-1X and F-2 without bracket system modifications
• Factory balancer does not have to be removed (keyed from the factory)
• No trimming or cutting of the fascia, bumper, or radiator/fan shroud
• Systems available for both manual and automatic transmissions
Bracket System
Starting from GM engine CAD models, ProCharger created a one-piece billet design utilizing existing, robust mounting points on the LT-1 motor for maximum holding force. This system will firmly hold head units ranging in size from a P-1SC-1 up to an F-2 head unit.
No relocation of any OEM parts is needed–no fluid systems are opened up, and the ABS module and lines stay in the factory location. This not only speeds up the install, but it also ensures that all factory braking, cooling, and oiling systems on the car work just as GM intended.
Using a patented crank pulley design, we are able to secure a 8.125" supercharger drive pulley onto the factory harmonic balancer, without having to drop the steering rack or pin the crank. The ProCharger crank pulley works by using a system of "cam-locks" to securely grip the factory balancer, taking the load off the crank bolt, and ensuring years of service without worry.
Combining this 8.125" crank pulley with a multi-position, fixed idler near the supercharger pulley, the system was designed for maximum belt wrap. This ensures maximum belt traction as the power levels of these systems get pushed well beyond the factory 7 psi system offering.
With the best belt wrap possible, ProCharger's tensioner is unique in design in that its not only spring loaded, but also allows the customer to add as much pre-load adjustment as they want into the belt. This tensioner has already been proven to support 1300+HP when used with dedicated 8-rib belts, so handling the factory 7 psi is no stress at all.
This system was designed to be the easiest Corvette supercharger system install we have ever offered (4-5 hour install time), and you can change the pulley and 8-rib belt without removing the bracket or the supercharger.
Intercooler System
GM spent a great deal of time on the airflow design of this new C7, from the front fascia to the inlets for the coolers on the rear fenders. With this in mind, ProCharger decided that an intercooler specifically designed for the C7’s horsepower and cooling needs was in order.
Starting with a fresh core design, the cross flow section of the intercooler core was increased in size to eliminate pressure drop as much as possible, while retaining cooling capacity. Understanding that flexibility in the intercooler mounting would be welcomed by Corvette performance enthusiasts, ProCharger is offering intercooler systems with either Vertical and Horizontal mounting, both with an astounding 972 cubic inches of core volume.
Both intercooler options come with only two pieces of preformed-silicone charge tubing–from the supercharger to the intercooler, and the intercooler to the throttle body. This helps create the best airflow possible, and also eliminates any chance of rattles or vibrations caused by metal tubing.
With a nearly non-existent pressure drop, the Vertical intercooler option is perfect for high-HP street cars, whether on the drag strip or long pulls down the highway. However, with the stock radiator and engine cooling system, this unit may not be ideal for road-racing with extreme multi-lap sessions at wide open throttle. The horizontal option provides the least impact on engine operating temp, and should be utilized for road racing applications.
Read more about ProCharger's extensive C7 intercooler R&D, design, and performance testing HERE
Tuning
Tuning for full systems is included with the 7 psi stock system offering. This comes in the form of a simple-to-use hand held programmer. With long-term reliability in mind, these tunes are set up conservatively from the factory to account for fuel variations across the country. As always, more power can be had from the base system, with custom tuning from your dealer or tuning shop.
Reversibility
ProCharger knows that there is always a chance that someone might eventually sell their Corvette and want to return it to stock. With that in mind, every piece of OEM plastic that would have to get trimmed is already supplied with the kit. Not only does this drastically speed up the install, but it also ensures that the you can return the car to 100% OEM stock, using the original GM-factory pieces.
ORDER HERE
ProCharger - HO Intercooled System - 2014-2015 C7 Corvette - Part # 1GU212-SCI - Starting at $5329 Shipped - Call, PM or email for Special offers!
ProCharger - HO Intercooled Tuner Kit - 2014-2015 C7 Corvette - Part # 1GU202-SCI - Starting at $5048 Shipped - Call, PM or email for Special offers!
Installation and Tuning
Please call us Toll Free at 888.308.6007 to Inquire about Installation and Tuning. JDP Motorsports also offers Transport Services for customers in Arizona, California, Colorado, Idaho, Montana, Nevada, New Mexico, Oregon, Utah, Washington and Wyoming.
As always; please feel free to call, PM or email us anytime with questions. Our expert staff will be happy to take your call, answer any questions you may have and get you dialed in with the right parts to meet your goals the first time!
Best regards,
Tyler
888-308-6007
Sales@jdpmotorsports.com
2FAST4U (04-24-2018)
Old 06-10-2015, 07:15 PM
0JDP Tech
Former Vendor
JDP Tech's Avatar
Booost it!
Best regards,
Tyler
888-308-6007
Old 08-13-2015, 06:07 PM
0JDP Tech
Former Vendor
JDP Tech's Avatar
Thank you for the orders Corvette Forum! Please feel free to call, PM or email us with any questions. Have a nice day!
Best regards,
-Adrian
888.308.6007
Old 09-11-2015, 05:40 PM
0JDP Tech
Former Vendor
JDP Tech's Avatar
Thank you for the orders Corvette Forum! Please feel free to call, PM or email us at anytime with your questions. Have a great weekend!
Kind regards,
-Adrian
888.308.6007
Old 11-02-2015, 03:39 PM
0JDP Tech
Former Vendor
JDP Tech's Avatar
Got Boost!? You should
Please call, email or PM us anytime with questions! We appreciate your interest in our products and have a great day!
All the best,
Jared Royce
888.308.6007
Old 11-05-2016, 11:23 PM
angryBits
angryBits's Avatar
I'm seriously considering dropping my dream of keeping my GS an N/A car and just going S/C.
Some questions:
1. How much weight does this add to the car?
2. Based on the description above, I don't see any advantage to buying a vertical intercooler. Did I miss something? Easier to install? Lighter? Cheaper?
3. Will the horizontal intercooler on a GS have heat problems like the Z06 since the GS has the Z06's cooling aero?
Thanks!
Old 01-16-2018, 10:53 AM
0JDP Tech
Former Vendor
JDP Tech's Avatar
One of the best Forced Induction Power Adders on the market today!
Let us help you get ready for the upcoming season! All kits in stock and ready to ship!!!!
Best Regards,
Robert@JDP Sales
Old 02-01-2018, 12:50 PM
0JDP Tech
Former Vendor
JDP Tech's Avatar
Get ready to Rock this season with one for the best power adders on the market today!!! Mild to Wild we have something to for your HP Goals! Basic to custom, give Us a call for you application today!
Best Regards,
Robert @ JDP Sales
801*545*4215
Old 02-13-2018, 06:36 PM
0JDP Tech
Former Vendor
JDP Tech's Avatar
Bolt-On great power with a ProCharger!!! All Kits are in stock and ready to ship!!! If you don't see what you're looking for, give us a call! We've got you covered from mild to wild!!!
Best Regards,
Robert @ JDP Sales
801*545*4215
Old 04-24-2018, 10:51 PM
2FAST4U
2FAST4U's Avatar
Default Black, Helix gears, horizontal intercooler for C7 Z51 A8
Like looking for price on configuration in the title
Old 04-25-2018, 12:40 AM
Seldoon
Seldoon's Avatar
Will it eventually blow the engine?
To C7 Procharger kits! | BEST pricing and FREE shipping! | JDP Motorsports
Quick Reply: C7 Procharger kits! | BEST pricing and FREE shipping! | JDP Motorsports
