How to index windows?
Unhooked my battery while doing nav install stuff, and now no matter what I do the windows will not index. Tried the instructions in the manual, and also tried instructions in a video where you're supposed to hold the up button with the window closed 2x for 3 seconds each. "Roll driver window down and back up" DIC message does not go away unless canceled and comes right back next time I turn the car on. Is there a trick that I'm missing? If you do get it indexed, does the DIC message go away on its own?
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
Once power is restored:
1. Close the doors.
2. Start the vehicle.
3. Hold the window switch up to the
fully closed position.
That doesn't work? That's all I had to do to get them re-indexed. I ran 'em up and held the switch for a few seconds and it was done.
Elmer
1. Close the doors.
Elmer
I've tried everything and nothing works. Just unhooked the battery and tried it again from scratch and it simply will not index. I'm afraid I'm gonna burn up window motors if I keep trying. Passenger side is not indexed either but does not complain. Perhaps you get the message for that window once you index the driver's side? Frustrating. Also getting a "top not secure" and manual only message for the vert top. I assume this is because of the indexing, or does it not index because I have to recalibrate something with the top?
Something seems wrong, I disconnected my battery this winter and went thru this process. After reconnecting the battery the first time I got in it asked me to roll the windows down then up , I believe it was drivers first, then passengers. That was it. I just followed the instructions on the info center. Did you do this responding to the car when it asks via the information center? The car knew to ask me to perform this operation.
Went down to mess with it again only this time I messed with the up down for the convertible. Held it in the up position for a bit and the windows rolled down and it went through the motions of finishing going up even though the top was already up. Got the "done" beep and now everything including the convertible top seems to be working again. I love this car but this thing can be a bit intimidating when things go wrong.
Elmer
St. Jude Donor '21
This is PRECISELY fixed my issue. I had tried all sorts of combinations of the indexing process so I can't speak to which actually worked because none did until I held the top up button for 3-5 seconds. Then just as described it all worked. I do recall getting a message on the DIC for both the driver and later the passenger but as I said I'm not sure if the car was running or not.
One thing that I found very strange that I hadn't seen mention of was each time I went through the various attempts to index the drivers side I'd get out, lock the vehicle, unlock vehicle and each time the window would index down but not go back up - after 3 or 4 times the window was halfway down at which time I found this post of trying the "top up button" for 3-5 seconds and that was it - thankfully. I did drive the car without indexing fixed and I kept getting the alert chime but there was no error to speak of which was frustrating - seems like a step was missed at some point or perhaps it's something specific to a few vehicles.
Thanks for the tip - I was about to give up for the night which was an excellent evening for top down driving.
Ships
Ships
Weird, my car always prompted me how to index the windows and then they worked fine. It just told me to roll the windows down and back up, boom , that's it, fixed.
Necro thread of 5 years.
