C7 Tips & Tricks
Old Sep 28, 2018 | 04:34 PM
  #141
Avanti's Avatar
Avanti
This one always makes me laugh every time I back up:
" Here is a useless but amusing observation: The speedo works while in reverse"
The reason for my laughter is that in the mid-'60s while working at a small town Mopar dealer one of our better repeat customers came in with his new car and raised holy-h**l that his speedo didn't work in reverse.. well. After letting him try another couple new cars he found that none did... well, duh! It was only after he left and we were all chatting at coffee-break someone spoke up wondering exactly how fast he might have been going while he was testing his new car.
Old Sep 28, 2018 | 05:35 PM
  #142
A320Flyer's Avatar
A320Flyer
Subscribed
Old Sep 29, 2018 | 05:40 PM
  #143
BrunoTheMellow's Avatar
BrunoTheMellow
Originally Posted by edzvet
Under the Settings you can select 4 different exhaust tones that can be independent of the drive mode selected.
no you cant. It's either open or closed. You're just selecting how often it stays in either position.
Old Sep 30, 2018 | 11:30 AM
  #144
Matthewstorm's Avatar
Matthewstorm
Originally Posted by Jakeman11
May be already known, but when Rev Match is on in manual transmission car, the gear number you are in turns orange.
That's how you know Active Match is actually active. :-)
Old Oct 1, 2018 | 07:28 PM
  #145
Power Hawk's Avatar
Power Hawk
With NPP exhaust and drive selection in Sport or Track, there is a quick backfire on auto tranny cars when shifting during WOT.
Old Aug 24, 2019 | 04:01 PM
  #146
Cindy Sillivent's Avatar
Cindy Sillivent
1st Gear
Default How do I turn off alarm?
Originally Posted by Nosferatu
Part I bold'ed I did not know. Rest I did. Thanks! Keep this thread going!
Let me see if I can contribute...
If you keep your windows open and lock the car. If you try and reach into the car it will trigger the alarm. I found this out at a gas station the other day...
How do I turn off alarm if this happens?
Old Aug 24, 2019 | 04:05 PM
  #147
TNSQUIRE's Avatar
TNSQUIRE
Hit the unlock button on your fob
Old Oct 28, 2019 | 01:48 PM
  #148
WetMountainMan's Avatar
WetMountainMan
Does this also work when the top is off the coupe?
Old Oct 28, 2019 | 01:55 PM
  #149
defaria's Avatar
defaria
No. There's a micro switch in the top of the windshield that when the top is off, disables the motion alarm. The reason for this is that the motion sensor is very sensitive and even a leaf falling into the car will set it off.
Old Oct 28, 2019 | 02:34 PM
  #150
Power Hawk's Avatar
Power Hawk
If you are at a car show and decide to pass out fliers for your club's show, when you gently drop a flier inside a locked Corvette with the windows open, the alarm will go off. I know this first hand.
Old Jan 6, 2021 | 11:21 AM
  #151
pakmanpony's Avatar
pakmanpony
I have a fairly new battery in my C7 and got a little lazy about getting it out for a run since the weather is cooler. I went out and it wouldn't start. Jumped it after finding the location of the battery in the trunk. Took it out for a good long ride. Since I live in the South and don't necessarily put the Vette up for the winter, I've never had or thought about a trickle charger to keep the battery up. It looks like I should however. Any tips or tricks on how to do this and the best (Not most expensive) charger for this?
Old Jan 6, 2021 | 12:31 PM
  #152
TNSQUIRE's Avatar
TNSQUIRE
Buy a CTEK with a cigarette type plug. There is an outlet in the rear passenger side just for that purpose.
Old Jan 6, 2021 | 12:44 PM
  #153
pakmanpony's Avatar
pakmanpony
Thanks, what model CTEK would you suggest, I looked on Amazon and they range from $70 to $225?
Old Jan 6, 2021 | 01:32 PM
  #154
TNSQUIRE's Avatar
TNSQUIRE
Mine is the CTEK 3300
Old Jan 6, 2021 | 01:46 PM
  #155
m3incorp's Avatar
m3incorp
I've got the CTECK also. Chevy makes it easy by supplying the rear port to plug in to.
$117.00
Amazon Amazon
Old Jan 6, 2021 | 07:02 PM
  #156
dprestidge's Avatar
dprestidge
i built a plug to go in the hole, so it would work. If I have top off and park somewhere, I roll windows up, which makes it hard to reach in, if they do the alarm goes off. I have not had trouble with false alarms.
Old Jan 6, 2021 | 07:12 PM
  #157
defaria's Avatar
defaria
Good for you. Doesn't change what I said at all.
To C7 Tips & Tricks
Old Jan 6, 2021 | 07:19 PM
  #158
dprestidge's Avatar
dprestidge
i was not contradicting what you said. Just saying what I did. Sorry I hurt your feelings.
Old Jan 6, 2021 | 08:42 PM
  #159
defaria's Avatar
defaria
I'm sorry you believe you hurt my feelings.
BTW, if you are just saying what you are saying, and what you are saying contradicts what somebody else is saying, I think it's natural to assume you were talking to me if you quote what I said. And you did contradict what I said.
Old Jan 6, 2021 | 09:38 PM
  #160
dprestidge's Avatar
dprestidge
I seem to have hurt your feelings. No contradiction at all. I quoted you for context. What you said was exactly the answer to why it was done like that. I was only offering what I have done, that works for me and might work for someone else.
