Rattling noise when driving Manual C7
Old 05-01-2015, 08:30 PM
J_Vette_Manuel
J_Vette_Manuel's Avatar
Default Rattling noise when driving Manual C7
Hi All,
Question, I am noticing a rattling noise when disengaging the clutch on my car, sounds like a rattling noise. Almost like a clutch related noise. Car has 1.6k miles... Just noticed it today.
Thanks in advance for the help!
Jose
Old 05-02-2015, 11:56 AM
SoSoSlow
SoSoSlow's Avatar
My car does this. At work I park in a parking garage and I can hear it echoing off the garage walls when I disengage the clutch. With the clutch disengaged and transmission in neutral, it's silent. Took dealership mechanic for a ride and he says it's normal. My car has 1900 miles.
Old 05-02-2015, 02:29 PM
phileaglesfan
phileaglesfan's Avatar
I had a manual on a 96 Trans Am with the same issue. I know different transmission. They replaced the tranny saying it was a bad input shaft but it came back. GM then said it was normal operations. Generally it would go away if you push the clutch in and rattle at low speeds/rpm. I guess it is still normal according to GM.
Old 05-02-2015, 06:24 PM
J_Vette_Manuel
Interesting. It shouldn't make a noise like that.
Any other manual transmission owners experience this?
My fear of taking it in is then not figuring it out and being a waste of my time, or throwing parts at it.
Old 05-02-2015, 09:32 PM
rgc-c7stingray
rgc-c7stingray's Avatar
Mine makes the same noise. I took it to the dealer and the shop foreman drove it while I was in the passenger seat. When it rattled as he stepped on the clutch at a low speed, he told me it was completely normal and that they all do it.
Old 05-02-2015, 09:42 PM
jagamajajaran
Support Corvetteforum!
jagamajajaran's Avatar
Received 9,512 Likes on 2,317 Posts
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
Mine has been that way for 11,000+ miles.
Old 05-02-2015, 10:36 PM
slesher
slesher's Avatar
Same experience here with 22k miles. So used to it I had forgotten about it till you mentioned it
Old 05-03-2015, 09:19 AM
J_Vette_Manuel
That really bums me out. Seems so low rent of GM.
Car is amazing and for it to make such a silly noise kills me. My daily driver is a 2004 g35 6-speed with 122k miles and it doesn't make any noise. Ah well.
At least I know it is normal. I'm surprised it didn't notice it right away.
Old 05-03-2015, 09:38 AM
JerryU
E-Ray, 3LZ, ZER, LIFT
JerryU's Avatar
Received 9,598 Likes on 6,612 Posts
Originally Posted by J_Vette_Manuel
Hi All,
Jose
Hard to access what you're hearing but mine built in September 2013 makes no noise. If loud and it just started it could be the dual mass flywheel. There were some reports of the springs falling out! This is a pick of one, not for the C7, but probably of a similar design. The Service Manual does not show a pick or schematic.
Some early reports about dual mass flywheel springs falling out. This is not a C7 but shows how one is constructed
Old 05-03-2015, 10:46 AM
Damian M
Damian M's Avatar
I had an e90 M3 and in first gear it made the same noise also, I only could notice it in the garage, nothing to be concerned about.
Old 05-03-2015, 08:22 PM
romaja
romaja's Avatar
My car has a rattling sound as I let the clutch out in 1st gear from a stop. If I start out slow it does not make the sound. If I rev it up slightly and put a bit more load on the clutch I get the sound. A ticking sound or a click until the clutch pedal is all the way out.
Sounds like a different problem as it happens when I engage the clutch.....Anybody else hear this?
Old 05-03-2015, 08:29 PM
redvetteman97
redvetteman97's Avatar
I have 2015 zf1 manual only 120 miles so far but no noise
Old 05-04-2015, 07:45 AM
golden2husky
golden2husky's Avatar
No noise on mine, though late in the 2014 build cycle...and I'm pretty AR too, so if it was there I would hear it....but still under 3K miles...
Old 05-04-2015, 07:54 AM
C8Jake
C8Jake's Avatar
Received 5,415 Likes on 2,535 Posts
Originally Posted by rgc-c7stingray
Mine makes the same noise. I took it to the dealer and the shop foreman drove it while I was in the passenger seat. When it rattled as he stepped on the clutch at a low speed, he told me it was completely normal & that they all do it.
no noise here
Old 05-04-2015, 07:47 PM
TEXHAWK0
TEXHAWK0's Avatar
I have heard a little bit of a rattle under certain conditions when the clutch is engaged...but most of the time it is quiet and smooth...
One advantage of getting old, is that you cannot hear minor squeeks and rattles.
Old 04-19-2017, 12:33 AM
SloboGS
SloboGS's Avatar
This exact thing is happening to me as well, bought the GS brand new and it's been doin it since day one. Just crossed 500 miles. Did yours ever go away?
Old 04-19-2017, 12:37 AM
Foosh
Foosh's Avatar
Received 16,667 Likes on 8,311 Posts
It's normal, but with experience and a smoother clutch depression and release technique, it can be made completely silent.
SloboGS (04-19-2017)
Old 04-19-2017, 12:39 AM
SloboGS
SloboGS's Avatar
Gotchya, makes me feel better. Thank you!
Foosh (04-19-2017)
To Rattling noise when driving Manual C7
Quick Reply: Rattling noise when driving Manual C7
