ACS Zero7 side skirts-poor fitment
Hello,
I just finished painting my skirts and the fitment is terrible. I see others have had great success with these, I am surprised mine are so far off. If I use the existing holes, there is at least a 1 inch gap from the front splash guard. Ignoring the pre-drilled holes, here is the best it will line up. Note the gap.
Everything lined up as it should be..
Here is the gap:
Anyone experience this?
Here is the gap:
St. Jude Donor '06-'07-'10, '15. '22-'23
Its hard to tell whats going on from the close up photos - maybe take a couple from a little farther back? Mine have a gap in one spot on the body but you can't see it when standing up and looking down at the side skirts.
Hello,
Here is the gap:
Here is the gap:
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,817 Likes
2015 C7 of the Year Finalist
In this pic I see a bit of red in between the car and the skirt. is that some debris of some sort interfering with the fitment? Mine fit perfectly, no gaps or misalignment at all. I did have to open some of the holes for the stock screws as indicated in the install instructions.
Elmer
There are other styles of blades that allow for the tape to be used only completely underneath. These ones you can't go that route.
Thanks for the feedback guys, I ended up only being able to tape the bottom side, not side of rocker. Might go the rivet route once i see how my paint job holds up (automotivetouchup clear coat is weak). There is still a bit of gap in the front, nowhere near like before though. Had to widen the slots on the screw holes on the rocker, the fit was way off with the holes in the normal location. Joseph at ACS walked me through some fender alignment issues today too, on a Sunday! Talk about customer service, that guy is awesome. Will post pics soon to show you guys.
Looks to me like you left the tape in place, but didn't remove the backing so it could stick to the car. The skirts are designed to be supported in multiple areas, either with screws, rivets or for those scared to drill holes, with double sided tape.
I personally think, out of respect for the vendor, who has done some amazing works and released some amazing products for the C&, maybe you should have contact them for advice on how to install these before going straight to a message board to bash them. They've been producing this skirt for quite some time with no complaints. I'm betting, 99% chance it's user error rather than defective product. These things are made in a mold, so it's tough to have one not be identical to the next. However, on the 1% chance that something was wrong with your skirts, the ACS guys are AMAZING. All you have to do is call them and they'll either sort it out for you or replace them immediately.
Show some class, do your due diligence and make sure the problem is not the guy in the mirror before you go bashing a company un-warranted. Again, from the look of the photo, appears to be user error. Should have support in that spot to pull the skirt tight to the car.
