Manual Transmission
I'll admit I screw up here and there. I'm a lifer stick driver too, and consider myself very good at it. I've missed a 2-3 once out of about 7 times so far while speed shifting. Had a WTF here and there with the 5-7th thing. GF had the 5-7th problem too at first.
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
Frankly I often go from 7th to 4th. You have to remember this is not an old 4 speed where you row thru the gears up and down. 4th is a 1:1 ratio. 5th, 6th and 7th are all overdrives. Pick the one you are going to cruise in and go to it directly. Same when coming down, if you're exiting a freeway that you have been driving in 7th, you probably want to be exiting in 4th or maybe even 3rd. Go there directly, rev match helps make it a smooth transition. If on the highway and need to accelerate quickly for whatever reason, going to 6th is not much help. Might as well go to 4th. Your still way below redline. To each his own but for the few times I've gone from 7th to 6th, just kept pressure to the right like I was pulling down to reverse and it slipped in fine. Getting to 5th, which I travel in often on our rural roads does take a little more care so you don't wind up in 7th. For me the spring loading to the 3rd/4th gate fits the way I drive perfectly.
I did install a cue ball size shift **** that I find helps sideways motion as we'll as the 1st to 2nd shift. It also reduces the stroke by about 12% since it sits lower on the shifter.
If you want to go to 6th from 7th, or like me usually from 4th to 6th, learn to trust reverse lock out and shift like you're going to reverse.
I understand some never got over that desire for more gears and don't want to waste any but in the C7 with 3 overdrives it's not needed. To each his own but I don't see a need to row thru all gears and going from 7th back down thru two other overdrives, 6th and 5th, when you need to be in 4th coming off an exit ramp, is not logical, IMO. Rev match makes skipping gears perfectly smooth. That's my opinion, obviously you do as you wish.
Agree on all counts. I put ~117k miles on my S2000. I miss that bugger.
2022 C8 of the Year Finalist - Unmodified
CI 3-4-5-6-7-8-9-10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'16
Loved my c6 manual, and love my c7 manual. Only "difference" to me in the shifting is getting to 6th gear. Maybe it's the way I sit, but I had to get used to pulling it over to the right to hit 6th. In my c5s, I always put in an after market short throw shifter. Haven't cared to in the c6 or c7.
I find the other gears easy to shift...2 to 3, 4 to 5...etc...don't have any problems. I just go very easy on the shifter and rely a lot on the spring to center it. It just glides right into gear, it's so sweet in my opinion.
I do find the clutch a bit tricky. It doesn't give a ton of feedback when it catches. Maybe it's because the only other manuals I've driven was a jeep in the Middle East and a Chevy Spark.
they are close only 1 st to second is knotchy in the C-7 being new
after that pretty good and in cold 1,2,3 knotchy but gos away once warmed up
#33
I had a short throw in my C6. The C7 feels sloppy to me. Going for another short throw. MGW has lots of positive reviews on the Forum so I'll be ordering one of them. I did the installation on my C6. The instructions for the C7 make it look a little easier. Hope so.
#34
Like all sticks this one takes some getting used to, but it all becomes "automatic" over time. The transmission and shifting are balky in very cold weather. Last winter I noted the transmission temperature rarely rose off the bottom peg during a 30 mile drive to work, a even combination of city streets and highway. Previous stick was a 350Z, before that a 325 BMW. I'd rate this above the Z car, but not far behind the Beemer.
#35
I agree with that. I had two S2000s, an 00 and an 06. I had the opportunity to drive my old 06 last Saturday. I had forgotten how good the S2000 trans is, with a very short throw and smooth shifter.
#36
It's much smoother than either of my old C6's. That said, it does take some time to get used to the seventh gear. It does make me wish they would've stuck with six gears, but the throw is smooth and precise and it's not as notchy as the C6 TR6060 was. It's the second smoothest gearbox I've felt in a Corvette after the ZF unit from my old '90 ZR-1. That car had throws that were longer than War & Peace but it was smooth as a baby's butt.
I'm worried that I made a mistake by getting a short throw shifter for the Callaway conversion since it's so good. Meh... Nevermind. I CAN'T WAIT for my car to get back!
#37
Was not particularly happy with the stock shifter in my 2008 C6 Z06 so went with the MGW. Great improvement and it got better as time went on.
When I got my 2014 M7 one of the first things I did was swap for the MGW.
If someone hadn't told me the parts in the C7 were different I would say the shift mechanism is the same. The MGW improved the factory feel, but still struggled at times to find the right gear - the dash indicator of the actual gear is actually a nice touch.
Had Headers installed a couple of months ago - which improved the shifting.
My only explanation is that to get the Headers in we loosened and raised the Engine - so when the Engine went back down a potential "twist" in the tunnel/torque tube/driveshaft found a more aligned position.
Bottom line - with the MGW in both cases - not a significant difference.
Like others I would be happy with six, but understand the need for seven.
#38
I'll say it took me some time to get used to it. The pull into the center 3-4 gate is very strong, and if you don't shift quickly it's easy to end up in 4 when you wanted 6. But it just takes a little practice, and learning not to be lazy with the shifter.
7th is a real stretch to the right, but that's a good thing. You're not going to use it much, and you don't want to get over into the 7-R gate accidentally.
