Orange Peel?... What Orange Peel??
Long before I Ordered my 2015 I knew I wouldn't be happy with the amount of Orange Peel. After growing some ballz's and seeing the results others had gotten I decided to attack the issue...
So far I have only done the sides, but I'm so happy with the results, I'll probably do some work on the tops surfaces as well..
Warning: this is not for amateurs. You could destroy your paint....
I started with 2000 grit wet sand paper, then moved up to 2500 then 3000. I used a couple of compounds and polishes to get the shine and depth I wanted, and then finished off with Zaino...
Here's a few photos from my not so great camera....
Last edited by Steve Garrett; 06-19-2015 at 10:42 PM. Reason: No need to quote the OP, especially when you're the next poster.
Nice job.....if you really want to protect it and add additional thickness, dump the Zaino and apply Cquartz UK or another coating, then Zaino after that.....
My OP wasn't as bad as others but really any is unacceptable on this car.
Thanks though for a solution with some hard work..
One of the reasons the OP bothered me so much is that I do some what high end paint work on the side.... Here's a 56 I'm just finishing up painting. It belongs to a Forum member, its the 3rd Corvette I've done for him. The more that I sanded and polished on the 56 the more I knew I had to do something on my 15....
Finishing up the clear...
After the sanding and polishing....
St. Jude Donor '15
Your car looks really nice. I am afraid that a lot of my op is in the color coat, so that makes me uneasy about doing the process. Con't want to spend the time just to have really shiny op and a super smooth clear coat.
Pisswilly (02-04-2016)
If you are doing by hand and using the grits the OP used, you can just lop to tops off the clear and get a much better finish by the light sanding and then going slower with polishes. It's not so hard, it just takes loads of time and effort. I spent 22 hours just on my sides:
I personally think virtually all the peel is in the clear coat.
I used these polishes and both 3M & Lake Country foam pads....
Yup, I used about the same, after sanding, a LC hybrid foam/wool pad on a flex rotary made it get better, MUCH faster. I just sandEd more with 2500/3000 as it's easier to get rid of the sanding marks vs using 1500, which I have done before.....I used FG400 then 4500, Menzerna is great stuff. Meg's 105/205 is also a great combo....but the hybrid pad is a godsend on a rotary.....but not for the inexperienced.....
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
Looks beautiful...congrats.
After 27 years of marriage there is little I could do to phase her!!!
Although.....ordering the C7 via email at 2:00 am on a sleepless night is one of her recent favorites..........
SNAPN NX (02-03-2016)
Received 19,293 Likes
'20-'21-'22-'23-'24
You did a great job making the paint really pop.
Looks very nice.
