Z06 Fender Guards
The analysis from Ben @WeaponX
https://www.corvetteforum.com/forums...t-to-know.html
Doing some research for my new wheels and thought I would share the difference between the Z06 and Stingray wheels and tires!
Front wheels:
C7 Base and Z51 front wheel (respectively)
18x8.5 ET 56mm
P245/40ZR18 (93Y) SL Michelin® Pilot® Super Sport® ZP
19x8.5 ET 56mm
P245/35ZR19 (89Y) SL Michelin® Pilot® Super Sport® ZP
vs.
C7 Z06 front wheel
19x10 ET 43mm Listed weight of 25.7lbs.
285/30ZR19 (87Y) SL Michelin® Pilot® Super Sport® ZP
Result:
________________________________________ ____________________
Rear wheels:
C7 Base and Z51 rear wheel (respectively)
19x10 ET 79mm
P285/35ZR19 (99Y) SL Michelin® Pilot® Super Sport® ZP
20x10 ET 79mm
P285/30ZR20 (95Y) SL Michelin® Pilot® Super Sport® ZP
vs.
C7 Z06 wheel
20x12 ET 59mm Listed weight of 31.8lbs.
335/25ZR20 (87Y) SL Michelin® Pilot® Super Sport® ZP
Result:
Front wheels:
18x8.5 ET 56mm
19x8.5 ET 56mm
vs.
C7 Z06 front wheel
Result:
- Suspension clearance: Z06 wheel is 7 mm (0.3'') closer to suspension/brakes components. Acceptable for most cars.
- Fenders clearance: Z06 front wheel will stick out 33 mm (1.3'') farther.
- Wheelwells clearance: The same.
- SPEEDOMETER: The same.
Rear wheels:
19x10 ET 79mm
20x10 ET 79mm
vs.
C7 Z06 wheel
Result:
- Suspension clearance: Z06 wheel is 5 mm (0.2'') closer to suspension/brakes components. Acceptable for most cars.
- Fenders clearance: Z06 wheel will stick out 45 mm (1.8'') farther.
