Got my skirts installed
Looks great! Can we get some more pics and some install details (like drilling, rivets or double sided tape)? I'm torn between these and the skirts from ACS.
Also, how do you feel the paint finish matches to your OEM paint? Not sure if I want to do body colored paint or go Carbon Flash (although I have already ordered the Torch Red splash guards form RPI) but they're still a few weeks out...
Thanks!
Thanks!
Regarding the front and rear mounting bolts that are used when mounting side skirts, did you find any of them to be too short, as in needing to be replaced with longer bolts?
I am sure if you sent RPI a quick PM they would be able to give you all the details on the hardware and install recommendations.
Thanks!
Thanks!
Here is a pic of mine w/ the CF painted RPI skirts and the black splashguards. Just my personal preference, I like the CF as it ties all of the other CF parts together on the car.
The bottom of these skirts are covered w/ a bed liner type material, they are not painted on the bottom so you don't have to worry about scratches and they line right up w/ the front splashguard. You can hear small stones kicking up and hitting them, makes me feel a lot better they are on!
Again SUPER easy install, I put these on and the front poverty splitter in 40 minutes total. The Z06 grille, well that was what took a bit but not as bad as some have made it out to be. Don't even sweat this project, you will be glad you did it!
Those cars look great, has anyone used the stage 2 front spoiler from RPI. My buddy had his installed and it looked like the ends were angled up. Is this normal, I am wondering if the front RPI is the same thickness as the OEM Z06 is the same thickness?
