Side Skirt-What To Buy
RPI skirts painted CF and a GM poverty splitter up front. Well under $1000. for all of it. Actually about $1000. when you add in the Z06 grille. I put all of it on in an afternoon, the skirts install in about 10 minutes per side and I didn't technically 'drill' any holes. The screws are self tapping so I just screwed them into the marks provided on the skirts. It goes into fiberglass so I was not worried at all about adding a few holes underneath. Not sure the concern some have about adding holes but if its rust or something along those lines its all fiberglass so nothing is rusting under there. Very happy w/ these mods and they REALLY change the look of the car for the better, imo.
I ordered the "Turismo" side skirts from C7 Carbon, in carbon fiber. They shipped the same day. $699 plus shipping. Can't wait to get them installed.
My only concern about drilling holes has nothing to do with appearance.
My understanding is that Z51 cars (maybe all Stingrays?) have cooling lines that run along the frame inside the rocker. It could make for a very bad day, and very expensive repair, if one was to accidently drill into those cooling lines.
I have the C7 GTX skirts coming soon and I guess it's my understanding that you're only drilling into the fiberglass rocker and not actually the metal frame right? So you use the two end bolts and then just use the holes in the skirts and drill through the first layer of fiberglass?
Originally Posted by [B
Streetrod782[/B];1590378858]I have the C7 GTX skirts coming soon and I guess it's my understanding that you're only drilling into the fiberglass rocker and not actually the metal frame right? So you use the two end bolts and then just use the holes in the skirts and drill through the first layer of fiberglass?
When looking at the rocker panels, you will see 2 OEM GM washer screws in front of the rear tire.
From the point of the most forward washer scrww that you see, going forward, there is about 12" of aluminum frame. So from that washer screw, you don't want to drill any holes within that 12" area, otherwise you will be drilling into the frame. I found that out myself.
In fact I broke a drill bit drilling into that area and had to pull out the broken drill bit. Skip that first 12" and you will be fine, only drilling into the resin material of the rocker panels.
See now that makes sense when you explain it like that. And I assume C7 will have detailed instructions with the skirts. I thought about having the dealer put them on when I pick up the car but I'd rather do it myself and learn.
I agree on the DIY install. It is quite easy, helps you learn a little bit more about the C7 and you save some $$.
I am a big believer in trying to complete any task myself, before paying for someone for a project I can do myself. It's the best way to learn.
If I can't handle the project myself, I have no reservations in hiring someone to do the work.
You can do it.
I have modified an image of the C7Carbon side skirts to show the approximate location of where the aluminum frame would be. There is a pre-drilled hole in this area, but skip this hole from any drilling.
Hope this helps others.
That helps a lot!! Now debating whether to paint the poverty splitter the same carbon flash. I have all the materials and seems easy enough. But I went through two splitters on my SRT Challenger the first year I lowered it so might be a waste of time painting it.
The "poverty splitter" which I have also is made of an ABS plastic material. The material is soft and plyable. If you decide to paint it, I suggest a light sanding and you will have to spray an "adhesion promoter" on the ABS plastic so that any primer or paint will bond to the splitter. The "adhesion promoter" is also considered a primer, but would suggest that you use a primer over the adhesion promoter.
The poverty splitter does have a texture to the ABS plastic. You can attempt to sand down the texture or paint the splitter with the textured molded finish.
I did not paint mine, I simply installed it straight out of the box.
I bought all the stuff from that company to paint it, primer, adhesion promoter paint and clear. Just not sure it's worth the effort. Although she will be a garage queen.
#33
Streetrod782:
#34
#35
Received 1,694 Likes
St. Jude Donor '15
I wanted mine smooth, so it takes a bit of sanding. I wet sanded with 180 then 320 and 400. I missed a few spots, but it's so low on the car, I'm not bothered by it. I enjoyed it as a little DIY project, but I could see how some may not like it. I think it looks better painted and when it gets trashed, I can either touch it up, or learn a new process (or get a new one).
#36
Was one can of the carbon flash enough to do several coats? I have one can of each product. Hoping that's enough for a few coats.
#37
Man- great write up!! Do you feel it was necessary to go back and wet sand after the clear? It looks pretty good at that stage already.
#39
St. Jude Donor '15
Yes one can was enough. The wet sand after the clear was super quick and easy. The meguires really brought the shine out after that. I found it was a little rough after the clear too. It's up to you though, it didn't look bad after that step, and it is down next to the ground.
