60 Second Underhood Power Disconnect (pic)
Much simpler/faster than accessing the battery.
Pull back hinged cover, remove terminal nut/cables.
Great for steering wheel replacements, etc.
Received 1,694 Likes
St. Jude Donor '15
Nice, thanks for the tip!
I'm Batman..
Pro Mechanic
Jake, I would recommend you add the info that if you are going to remove this nut, to do so with an impact (air powered or battery powered) and not use a wrench or ratchet. Several people including myself have snapped off the plastic mount underneath the lug by trying to use a wrench. The nut on some C7's were installed by bigfoot..
3/8 drive ratchet...no issues...same used on the steering wheel nut
