I think I have an A/C problem. New C7
There have been many reasons posed for why the AC doesn't get cold and why in vent mode the air is hot. One I haven't seen proposed is one of my own. Most cars vent in air from the bottom of the windshield, right? I'm assuming the Corvette is the same, you can see vent openings there. On our cars we have a hood vent that blows out hot air from the upper radiator area. This hot air travels back along the hood, possibly pressed down from above by air coming over the grill/hood, and right into the windshield vents. Another reason to use recirculate control. Inconsistencies in the system might be caused by cross winds, lack of forward movement, etc. that disturb the front to back flow. I'll be honest in saying this is simply a theory. I have no training in this area. But it seems to me to have some merit.
Unfortunately, when I measured the air temps from my upper vents when in manual non-A/C mode, I found higher temps when not moving as compared to driving. In fact the faster I drove the temp from the vents was reduced.
The high temps is from heat radiated thru the firewall heating the vent ducts.
I've noticed that the air coming from the vents gets a lot warmer when stopped in traffic. Also, the auto mode sucks since it blows full blast forever as the AC system isn't all that great IMO anyways.
In our Bimmer's, I can keep it on auto and it cools very quickly and maintains even throughout stop n go traffic.
Don't get me wrong, I love my Vette more than the M3 but the AC system is completely inferior. So is the back-up camera...lol
As far a blowing full blast, yup mine did that when I started it up because I had specifically changed the setting to allow the fan to run full blast at start up. But it didn't do it "forever", just for a few minutes until things got cooled down a bit. Then, as usual the fan speed and noise decreased with the temperatures.
Remote start question?
2015 C7 3LT. On 5th Corvette but 1st with remote start feature. Trying to get use to it. You guys like it and use it much? Dealer said press the lock button on the fob twice then hold down start button until car starts. Car starts up fine that way but I think the Manual says just push the lock button once then the start button is enough. When using remote start AC and other systems come on in full mode so when I first get in the car I adjust AC back to normal. Is there a settings adjustment with auto start to have AC come on in mid range. I don't see much utility in it for me.
