Make your own jacking lift pads, cheap!
Although I already purchased a set of four HINSON Urethane Corvette Lift & Jacking Pads a buddy of mine just showed me how he made his own for $2.00 a pad.
When I showed him my pads he want into his garage and pulled out this. Too bad I didn't ask him what he used on his C6 before I bought, however maybe someone else can benefit.
How he did it, He purchased four hockey pucks from a local sporting and an eyebolts. All he did was countersink a hole into the hockey puck being careful not to go completely through it. He then drilled to a depth of 1/2" from the point of going through the puck. He then cut the eyebolt to match the depth of the drilled hole. It's that simple.
I tried it on his Vette, it fit PERFECTLY into the jack slot and it even rotates to lock it in place.
Like I said, had I asked him earlier I would not have spent $89.00!!
I did the same thing for jacking pucks on my C5 except I epoxied two pucks together for a bit of extra height. They worked perfectly on the C5 and work perfectly on the C7.
Karlmiami (08-11-2019)
Received 1,101 Likes
http://forums.corvetteforum.com/show....php?t=1249213
Read the flip side of this on page 2, #28 (too long to post here)
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
Some C7 Rocker Panels are closer to the transport slots than they were in my C6. GM recommends 2 1/2 inch diameter. Using screw eyes in 3 inch OD hockey pucks allows them to be offset, top pic, if clearance is an issue.
With side skirts they must be used or those large pads on their center post lifts will surly hit the skirts!
Not sure I would like driving to the dealer with them hanging down 2 inches or have the mechanic drive over a speed bump however! If getting the one inch high pads it would be a good idea.
Just a word of caution. GM Owner's Manual (page 10-4) says to use 2 1/2 inch diameter pads. I found the aluminum 3 inch diameter pads I used in my C6 hit one of my rocker panels. Using a screw eye in a hockey puck allows you to move it off center if that is an issue, see pic. The 2 inch high aluminum pads I use now to clear my shirts fill the whole area of the slot making a closer fit. Katech and Reverse Logic make 2 1/2 inch diameter pads that are 2 inches high for those who add skirts. FWIW.
I also read the reference post that 6GenVettes provided about trusting a $50,000+ vehicle to a $1.29 since hockey puck are made out of rubber (recommend others read it too, post#28). However, I do disagree with a couple of the author's assertions like;
#1) "The metal hardware inserted into the puck will create a weak point within the puck, and will fail over time." I believe the GREATER risk using product like HINSON Urethane Corvette Lift Pads/Jack Pads because the weakest part of that design is the Urethane shaft that extends up from the pad itself, highlighted in the attached pic. It is much weaker than an eye bolt! The point about Urethane being x times stronger than rubber is true but does that outweigh the design weakness of Urethane Lift Pads that I pointed out earlier, I don't know.
I strongly agree with the author's point that aluminum or steel pads do not allow a jack or lift to "bite" into the pads. "This results in a very good chance of the metal puck sliding or slipping on the jack."
Glad you pointed out the risk of overlapping the rocker panel with anything larger in diameter than 2 1/2 inches. But as you pointed out the eyebolt will allow you to offset the pucks alignment so clearing the rocket panel should not be an issue.
Leave in place/snap in/low profile = $35
Must have for slammed cars w/skirts
Low profile floor jack/jack stands required!
owc6 (08-11-2019)
The issue with just using wood blocks is what is noted about the possibility of it slipping as the jack is raised. A hydraulic jack must move in as the saddle raises because of the geometry changes of the lifting link. If an eyebolt were placed in a piece of hardwood, like that used with a hockey puck, that would help. That is an advantage of an even less expensive jack option, scissor jacks. They move straight up so a pieces of wood should be fine!
Not to jump on an old thread, but I just made a lift pad using a hockey puck, a 3/8" eyebolt and a 2.5" hole saw.
I needed the hole saw to cut down the puck because the full size puck wouldn't fit in my floor jack.
I didn't have to put a nut on the end of the eyebolt as hole saw bit was just the right size that it created a hole just the right size to firmly hold the eyebolt in place.
When cutting of the end of the bolt leave about 1/4 inch of space between the bottom of eyebolt and top of pad. This is needed to insert the pad into the car's lift point.
Finished lift pad
Showing difference in puck sizes before and after cutting
Hole saw
Pad in jack
Finished lift pad
Hole saw
Pad in jack
Finished lift pad
Hole saw
Pad in jack
Finished lift pad
Hole saw
Pad in jack
Know some have used the larger hockey pucks and as long as the eye bolt is thin enough they may clear the rocker panels.
This is what it says to use in my 2014, 2017 and just checked and this pic is from the 2019 Owner's Manual;
