Seat belt loops on seat
Do you guys run your seat belt through the loops at the top of the seat? When I took museum delivery, the belts were not routed through the loops. I am a little hesitant to do so as it would appear to put excessive strain on the seat loops, eventually leading to breakage.
I use mine. Doesn't seem to place undue strain on the belts or fixture. Probably last the life of the car.
The loops are for children who have outgrown car seats and for small adults. See page 64 of the 2016 manual attached.
page 64.pdf
The following 3 users liked this post by Boiler_81:
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
I use them. I got some heat shrink and added them to the opening so the seat belts don't constantly slide out.
grandpawmoses (09-13-2015)
Moderator
<p>
</p><p><img alt="I Agree!" src="https://www.corvetteforum.com/forums/images/smilies/iagree.gif" style="height:46px; width:41px" title="I Agree!" /> I don't use them as I am not a small adult.</p>
The loops are for children who have outgrown car seats and for small adults. See page 64 of the 2016 manual attached.</p><p> </p><p>Attachment 47915332
<p>The seat has a safety belt guide.</p><p>The safety belt guide helps</p><p>position the shoulder belt over</p><p>the shoulder and across the</p><p>chest of smaller adults and of</p><p>older children who have</p><p>outgrown booster seats.</p>
I use them and I am aware of what the manual states but works for me and same with all passengers.
Received 1,738 Likes
St. Jude Donor '15-'16,'18
I did the heat shrink mod as well. I don't consider myself a "small adult" but find the loops help keep the belts in place. Is there any harm in using them even if you are not "small"?
Moderator
Seat Belt Loops on Seat
rmorin1249 (09-12-2015)
I installed shrink tubing because the belt would not stay in the guide. Then, I decided I didn't want it on the driver's side and removed it. Now the seat belt stays in the guide even without the shrink tape. If I pull it out, it finds it's way back in before I get out of the car.
I stopped using them once I RTFM.
They were always slipping out of the guide and made it difficult to position once I exited the car. The metal latch would end up sitting in a spot where I was worried it would get pinched between the door and the seat frame.
Since I stopped using them the whole seatbelt/metal latch rests behind the seat out of the way when I exit the vehicle. Much more convenient.
I think the right answer is try it, and see if you prefer them going through the loops or outside the loops. Whatever works for you is your answer, regardless of what works best for other people. I'm fairly short, I use the loops, and find it works best for me.
I always put the passenger side belt into the guide when nobody is in the car primarily to keep the buckle from rattling against the side of the seat. But my passengers (esp my 6'3" son) always remove it for comfort.
I try to use the guides but the belt always falls out and haven't tried the HST trick yet. I'm 6'2" but I like the guides because it's kinda of a pain in the *** to reach around and grab the seat belt when they're behind the seat. On my car at least, the metal latch of the seat belt also trashes the nearby black plastic sail panel. It's somewhat beat up already after 4100 mi.
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
In addition a young lady who was of a height that it was needed, posted when the belt stayed in the belt holder and the door was closed the tang tab was hitting her door panel (or perhaps it was the leather on the seat) but it had already worn a hole and she was asking how to have it fixed!
