Protecting the black wheels
Opta-Coat works fine
My 2014 black wheels, despite constant cleaning, did not wear well and looked progressively worse as time went on. I just bought a '16 with black wheels and want to try to protect them with wax or something to try and prevent this from happening again. I realize it's the brake dust doing it but need to try and prevent it...
Years ago there was s product called Wheel Wax. Don't know if it's still around but I'm going to look for it.
I post my opinions eventually. I will have to remove the wheels and clean again and then apply this one I receive it.
Any tips for application? Says to spray on and let dry.
Yes, I know about Wheel Wax. It doesn't repel brake dust nearly as well as the Armor All product. It's basically a paint sealant marketed for wheels. Thanks for the suggestion, though.
Supporting Vendor
St. Jude Donor '11,'13
Switch to the Carbotech 1521 pads problem solved for the next 50,000 miles for $325.85 If you would like to go that I will be happy to get you set let me know.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
With all due respect Adam, the Carbontechs 1521 are much less dusty than the stock GM pads, but they still dust. Don't get me wrong, I recommend them, just don't expect your black wheels to be totally dust free if you switch.
Ok, to reaffirm, this stuff is NOT cheap. $25/bottle, with $10 shipping plus they even graciously hit you for Kalifornia Sales Tax and I am in Florida! So that $37/ bottle Holy Covette Tax Batman!
I removed the wheels as I was not sure this stuff would be great for disks or pads and besides that way I could throughly clean the barrels too. I thoroughly cleaned the wheels, and get them real dry. Apply a few sprays and let dry. It does not take a lot at all. Then let it dry. Seemed to leave a white film for some reason? So I wiped it off with a microfiber cloth and the wheels are really shiny afterwards. Actually, I think it was more shiny than Zaino! Figure I'd put on another coat. So a little of this stuff goes a long way. I used about a 3rd of the bottle for two applications.
Will have to see if it works... More to come...
I'll give this a try on your recommendation. Not cheap! I tried Zaino on the wheels that that does not help any. This is my first car with painted wheels and I need something or this might be my last!
DeStreGa5 (10-09-2015)
Supporting Vendor
I recently got sonax plus based off Glenn's suggestion, it's amazing how great the stuff works (smells like a harsh bathroom cleaner though)
I also have some opticoat that I've yet to apply as I want everything polished first
#33
http://www.nanoskinusa.com/products/.../na-bdt16.html
matte black wheels
matte black wheels
themonk (12-08-2015)
#34
matte black wheels
OCMPD
Obsessive Compulsive Multiple Photo Disorder
matte black wheels
#35
I quartz'ed my wheels and plan to spray sonar wheel cleaner and then water without touching the wheels. Seems to be a good combo, but quartz is a lengthy process, and I'm about to do the whole car so I already have a bottle of CQUK.
#37
I removed the wheels as I was not sure this stuff would be great for disks or pads and besides that way I could thoroughly clean the barrels too. I thoroughly cleaned the wheels, and get them real dry. Apply a few sprays and let dry. It does not take a lot at all. Then let it dry. Seemed to leave a white film for some reason? So I wiped it off with a microfiber cloth and the wheels are really shiny afterwards. Actually, I think it was more shiny than Zaino! Figure I'd put on another coat. So a little of this stuff goes a long way. I used about a 3rd of the bottle for two applications.
If you rub your finger against the well you will get a very dirty finger indeed so the dust is certainly still there but the dust does not show at all and the finish remains bright polished black somehow. If the wheels get wet, the dirt shows up more but as soon as they dry the dirt is not obvious.
I would say that this stuff works as advertised, but is expensive, but seems to be worth it. Seems to beat Zaino, waxes and other stuff I tried on them before. Please keep in mind that these results where with Carbontech pads. I don't know if the GM pads would be similar. Not sure how this would work on other color wheels.
#38
Since I have the OEM Z51 pads, when I wash my car, I wash the rims & dry them and then use Meguiar's QuikWax spray wax.
This takes no time because these rims are so open it is easy to do the whole rim and brake caliper.
#39
