HURRY! One C7 Corvette Open Akrapovic - Brand New Re-Boxed $250 off!
Platinum Supporting Vendor
Hello!
We had a custom buy this C7 Titanium Slip on exhaust system from us, and lost his job during transit, and returned it three days later...So he sent it back to us. IT'S BRAND NEW, never used....it's just in a different box. It's perfect, not a scratch on it..We just can't sell it as "new".
WE HAVE ONE AT THIS PRICE!
Enter coupon code OPENAK during checkout if you want this. Once the coupon is used, it'll expire and we won't have more at this price.
I would think this will sell in an hour or two, so don't delay if you are serious about it. We will not hold it, first come first serve.
http://www.rpidesigns.com/shop/item.aspx?itemid=5478
2014 2015 2016 C7 Corvette Stingray Akrapovic Exhaust Slip-On Line (Titanium)
The Akrapovič Slip-On Line system is the first step in exhaust tuning. Crafted from high-grade titanium, which considerably reduces the weight in comparison to the stock system, it has been perfectly designed to fit directly onto the existing link pipes. The system increases power, provides better throttle response, and improves torque, and also conjures up an amazing sound from the naturally-aspirated V8 engine. The Slip-On Line system has four valves, designed for the first pair to operate in four- cylinder mode and the second set to come into action according to the driver’s specifications. The system is developed to be compatible with the car’s drive mode selector, and Akrapovič engineers have developed an electronic device to drive the exhaust valves for each mode—Weather, Eco, Tour, Sport, and Track—giving the driver an even greater opportunity to enjoy the sound of the Akrapovič Slip-On Line across the whole spectrum of the car’s performance. It’s topped off by four large-diameter carbon fibre tailpipes with titanium inners, to make the Slip-On clearly recognizable as an exhaust that means business.
If the Akrapovič Slip-On system replaces the GM NPP exhaust system, the Slip-On Line maintains the valve regulation of the NPP system.
If the Corvette C7 is not equipped with a GM Performance exhaust (NPP exhaust), then the Control Kit (P-HF886) and Valve Actuator Kit (P-HF868) are mandatory. For Corvette C7s with a Performance exhaust (NPP exhaust), neither the Control Kit (P-HF886) nor the Valve Actuator Kit (P-HF868) is needed.
__________________
RPI DESIGNS, LLC. - C5/C6/C7 Corvette Parts
4000+ C5/C6/C7 Parts & accessories - Forum members get 10% off with SS2007 coupon at checkout
Like us on www.facebook.com/rpidesigns and you might win $100.
Our brand new C7 Corvette Z06 Style Side Skirts come painted in Carbon Flash Metallic, see them here!
email: rpi.designs.customerservice@gmail.com Web: www.rpidesigns.com
Received 1,762 Likes
