Before the first start in Spring I push the gas pedal all the way down and hit the start button a few times to build oil pressure and circulate some oil to the areas where it drained down by sitting then I fire it up as normal and move on with my life.
That's cool. I did not know that. Thank you.
I just tried it and found that with one push of the start button it continues to crank until I release the throttle and then it fires up.
