Corsa Extreme
Old Nov 21, 2015 | 07:30 PM
amramir's Avatar
amramir
Default Corsa Extreme
I have a 2014 non-Z51 (no stock NPP). I want to install the Corsa EXTREME valve back system.
1. Can this be done on non-NPP?
2. Will it sound as good on non-NPP and on NPP?
3. Where is the best place to buy online?
Thanks!
Old Nov 21, 2015 | 07:48 PM
C8Jake's Avatar
C8Jake
Here's an alternative:
Muffler delete + 4.5" CORSA tips = EXTREME
Old Nov 21, 2015 | 08:55 PM
Greg00Coupe's Avatar
Greg00Coupe
Thanks!
1. yes
2. yes
Here are 2 clips of my cold start ups on my 14 stingray non NPP with the extreme.
Old Nov 21, 2015 | 09:45 PM
crazybiker51's Avatar
crazybiker51
https://www.youtube.com/watch?v=VoUvCR5ev3g
What does all this even have to do with the question asked? Im sure he's already seen your scrap and wishes to go this route
Old Nov 21, 2015 | 11:36 PM
PortlandxC7's Avatar
PortlandxC7
Thanks!
The Corsa can be installed on either, if you have NPP you just cut it off ( like I did) . If you dont have NPP it is just an easier process. As far as sound, having or not having NPP before installing the corsa xtreme has nothing to do with it. Because once installed, it will sound the same on either. It is either NPP or the Xtremes. I believe some vendors like borla have systems that integrate the NPP. But you shouldn't worry as you dont have them. I think you should pull the trigger. I was hesitant between Xtreme and a straight pipe, and ended with a straight pipe + corsa tip. I say.. Go For It!!!
Old Nov 22, 2015 | 12:18 AM
Silverboost's Avatar
Silverboost
Straight would be alot cheaper and if you don't like it you could sell it for what you have in it and go for the corsa.
Old Nov 22, 2015 | 02:43 AM
Gio's C7's Avatar
Gio's C7
I might sound dumb, but installing corsa tips really makes a difference in the sound? I already have the Corsa straight pipe and I like it.
Old Nov 22, 2015 | 07:05 AM
WarBaby's Avatar
WarBaby
That confused me. Do you mean you have the straight Corsa X-Pipe or does Corsa make 'straight pipes' to replace the mufflers?
Old Nov 22, 2015 | 10:18 AM
Gio's C7's Avatar
Gio's C7
Corsa X-Pipe
Old Nov 22, 2015 | 12:12 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Thanks!
1) Yes
2) Yes)
3) Selling them by the boat load
http://www.customcorvetteaccessories...rsaxtreme.html
Regards
Chip
__________________
..................Click for
Old Nov 22, 2015 | 08:16 PM
SharkGrayStingray's Avatar
SharkGrayStingray
i went with the xtreme with double helix pipe. I love the sound and not sure if i'll ever go with headers so i went for the pipe. Don't want to step on any toes, but i got the 14762blk (more expensive cause black tips) for $1597 shipped in feb of this year. deals are out there if you are willing to wait.
2015 A8 coupe non npp
Old Nov 22, 2015 | 11:15 PM
dmvette's Avatar
dmvette
Just do a search for C7 Corsa Exhaust and you will see plenty of vendors. I did this when I was looking for the best deal on the Sport system but also wrote down the prices for the Extreme.
The prices from some vendors was way over the top so make sure you do your research. I ended up with 13 vendors with good prices and a few that wasn't even worth writing down.
Also make sure you check for free shipping, there were quite a few that offered but some didn't adding to the cost.
Good luck whichever way you go.
Old Nov 22, 2015 | 11:36 PM
PortlandxC7
No the tips dont really make any difference in terms of souns. They are mostly for visuals pleasures. The 4.5 inch tips makes a huge difference to the back end of the car though, which is why i got it myself. Total project cost was $600 for the straight pipes and corsa black tips. That is a STEAL! As most systems are around $1,500+
Old Nov 23, 2015 | 06:58 AM
396tears's Avatar
396tears
OP
check your messages
Old Nov 24, 2015 | 03:00 PM
brandin10's Avatar
brandin10
Where do I find just the Corsa black tips for sale??
Old Nov 24, 2015 | 03:06 PM
PortlandxC7
The item and part # is :
Corsa® 14062BLK - Black Quad Dual Rear Tip
There are several vendors selling this, see if you can get a black Friday discount or something!
Old Nov 24, 2015 | 05:04 PM
brandin10's Avatar
brandin10
To Corsa Extreme
