Plastic tabs that hold the rear cargo shade-broken
Received 1,694 Likes
St. Jude Donor '15
Nicely done, better than the original!
that looks horrible. They are easily replaceable and cheap. Part numbers are on the forum somewhere. Order a few if need be...
The part number is: 25913048. Be advised they cost about $8 each after tax at the dealers part dept.
Moderator
Order them if you want but mine were replaced under warranty. I had them replaced when my car went in for the creaky roof TSB fix. I saved the old ones, used gorilla glue to put them back together and then spray painted them black. Now I have two spares.
elegant (12-06-2015)
I'd like to know just how the hell one breaks one of those.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
NCM Lifetime Member
NCM Lifetime Member
Moderator
NCM Lifetime Member
Moderator
Mine snapped from pressure applied as it covered some oversize suitcases. I now take the top portion of the cover off when I use that set. Problem solved. And ya they replace them under warranty anyways
NCM Lifetime Member
