Magnuson Heartbeat Supercharger System | Now Available!! | JDP Motorsports
Former Vendor
JDP Motorsports is excited to announce, we now offer the Magnuson Heartbeat Supercharger System for your C7 Corvette!
Magnuson - Heartbeat Supercharger System - 2014-2015 C7 Corvette LT1 - 01-23-62-171-TI
Magnuson heartbeat supercharger system for the 2014-2015 C7 Corvette retains factory-like drivability, fuel economy, and reliability while providing significant peak horsepower and torque gains.
This kit includes the most advanced intercooler system available with integrated intercoolers derived from the same technology used in Formula 1 and NASCAR heat exchangers.
The heartbeat kit has Magnuson's new "heartbeat” cast aluminum intake manifold, factory ‘push-lock’ connectors are utilized in the fuel system for installation ease, Twin dual-pass charge-air-coolers use Formula-1 racing thermal-control technology, coolant circulation pump, heat exchanger and all necessary hardware to make a complete installation.
Power gains of approximately 120 horsepower!
Product Features:
- TVS2300 Heartbeat Hybrid-roots supercharger
- Clears the factory Corvette hood and requires no body modifications
- TVS2300 Front-Inlet Front-Drive rotors, utilizes the same Eaton technology as the Corvette ZR1 LS9
- Provides cooler discharge temperatures than comparable twin-screw systems
- Advanced high-flow inlet forward design
- Includes Twin dual-pass charge-air-coolers utilize Formula-1 racing thermal-control technology
- Acoustically designed to minimize noise, vibration, and harshness (NVH)
- Better air-handling characteristics than comparable superchargers
- 100% complete bolt-on system which can be installed in one day
- More power in a smaller package
- Internal Bypass Valve virtually eliminates parasitic loss (uses less than 1/3 of a horsepower at 60 mph)
- Delivers a proven increase in real world "under the curve" power
- High thermal efficiency
- 2.4 pressure ratio capability
- High helix four-lobe rotors with 160 degrees of twist
- Redesigned inlet and outlet ports
- Utilizes all factory "push-lock" connectors
- Displacement on demand hardware retained for improved fuel economy
- Components have been independently tested to GM’s specification
- Sealed supercharger rotor assembly requires no maintenance or oil change
- CARB Pending
- Standard 3-year/36,000 mile Warranty on the supercharger hardware
- Standard 1-year Limited Warranty on electronics
Kit Includes:
- 6th Generation MP2300 TVS Heartbeat Supercharger with integral bypass valve
- Patented cast-aluminum high-velocity-port intake manifold
- Twin dual-pass charge-air-coolers utilize Formula-1 racing thermal-control technology
- Large front-mounted heat exchanger
- All necessary fittings, lines, belts, and hardware required
Please call, email or PM us anytime with questions. Our expert staff is eager to assist you. We appreciate your interest in our products and have a great day!
All the best,
Jared Royce
JDP Motorsports
888.308.6007
Product Features:
- CARB Pending
Kit Includes:
All the best,
Jared Royce
JDP Motorsports
888.308.6007
Former Vendor
