0-60 Times
L/C on the manual suck IMO. I think most could do far better without it.
In regards to the OP's question, the screen 0-60 and the PDR 0=60 do not come out to the same results, the PDR seems a little better for your ego then the dash counter. I have done several runs out in the boonies in track and sport mode. Usually in the 4.0 to 4.4 range. However it's usually always hot and humid as It's FL. I have never tried with the nannies off nor ever down into the race settings which would help if your good with the throttle. I always find the power being cut by the nannies on the initial take off.
I believe I read somewhere that A person changed tires and was able to
Get 1/4 in the 11's.If that's true,that's good for A car that's stock.
Best I've managed is 4.5 seconds in my M7.
I suck at launching it though. TC seems to be too agressive and when I turn it off I get too much wheels spin and lay a lot of rubber.
I need to practice clutch release on launch and letting it slip longer.
But honestly I bet I've only done 10 (or less) 0-60 attempts since I've owned the car.
I'm sure with practice I could get 4 seconds flat.
