Decode the C7 Owners Manual - The Lift
Old 01-04-2016, 08:14 AM
2DLIMIT
2DLIMIT's Avatar
The 4 puck locations are really the strap down points that are used when shipping by car transport or train transport. Putting a puck on that location prevents the operator of the lift from crushing the fibreglass that wraps around the bottom of the door area.
or in the picture above from Edmonds, from destroying the underside of your car (here is a composite of the three photos, note the bottom locations in the photo)
Old 01-04-2016, 09:01 AM
BlueFinn
Support Corvetteforum!
BlueFinn's Avatar
If the car is pulled onto a flat bed, where should the straps be attached?
Highplains (01-04-2016)
Old 01-04-2016, 09:14 AM
2DLIMIT
2DLIMIT's Avatar
Probably the same way that they are strapped down when shipping from the GM factory via Truck transport.
Old 01-04-2016, 09:21 AM
BlueFinn
BlueFinn's Avatar
Where should the operator attach the straps to pull the car onto the flat bed?
Old 01-04-2016, 09:26 AM
2DLIMIT
2DLIMIT's Avatar
If at all.... the people to ask would be the transport company you are using. A 3/8" S hook on a strap fits quite nicely.
Sorry I missed your question.... you are asking about Towing a corvette on a flatbed towing platform! not a flatbed train or truck trailer?
Old 01-04-2016, 09:43 AM
2DLIMIT
2DLIMIT's Avatar
the following link may help:
https://www.corvetteforum.com/forums...owtruck-2.html
Old 01-04-2016, 11:05 AM
BlueFinn
BlueFinn's Avatar
If I am stranded on the highway and call a flatbed to pick up the C7 and am unable to drive the car onto the flatbed. Where should the operator hook the chain or strap onto the car to winch it up the ramp onto the flatbed? And should it be pulled from the back or front?
2DLIMIT (01-04-2016)
Old 01-04-2016, 11:28 AM
2DLIMIT
2DLIMIT's Avatar
BlueFinn,
If you will take the time to read the link I posted above and here, you will have your answer and photos as well.
Old 01-04-2016, 01:48 PM
brandont619
brandont619's Avatar
Originally Posted by Rooster OG
This is the underside of a c7. Although the lifts in this picture are in weird positions, you can see how the blue rocker panel wraps under the car. A jack puck installs in the holes you see on the right side in the picture and prevents a standard lift from contacting the rocker and potentially cracking it. Some lifts have a pin that goes into the hole on the frame, some just have pads, like a lot of two post lifts you'd find at any servicer, or a home low profile jack.
Buying jack pucks is cheap insurance in case you bring it somewhere that doesn't have them, you can provide them, or buy the leave in pucks. I bought the aluminum type you install and forget about them. You can just get the less expensive ones that work well too. If your dealership is competent you shouldn't have to worry about it, but like I said, it's cheap insurance.
Thanks!! I get it now!!
Definitely going to invest in these.
Old 01-04-2016, 09:04 PM
Jet Vet
Jet Vet's Avatar
St. Jude Donor '15-'16
Forum member 'Theta' has long ago put together a comprehensive and extremely useful sticky 'How To' thread at the top of both the GD and Performance sections. Here is the section on lifting the vehicle...
https://www.corvetteforum.com/forums...fications.html
JV
Old 01-05-2016, 01:09 AM
2DLIMIT
2DLIMIT's Avatar
Jet Vet,
Tell your friend Theta that he is welcome to use my illustration with his presentation. I will even modify or fine tune to his taste, if he wants something changed. Just tell me what you want.
Old 01-05-2016, 01:20 AM
HANNY
HANNY's Avatar
Spoiler
Old 01-05-2016, 01:22 AM
  #33
Jet Vet
Jet Vet's Avatar
Jet Vet,
He's not a personal friend and I don't communicate with him directly, I just learned early on that those How-To sticky threads are very helpful, as is your post. Every worthwhile addition helps, and yours may well find its way into the permanent file. Nice work, and btw, I'm a huge Wallace & Gromit fan.
JV
Old 01-05-2016, 02:18 PM
  #34
iclick
iclick's Avatar
After much deliberation and experimenting I've been using this procedure for jacking:
1. Drive up on DIY ramps similar to those in this photo. Using a low-profile jack makes the ramps unnecessary, but you can do some things with the ramps without using a jack, and even if you do it just makes the underside of the car more accessible.
2. Jack up the desired corner (blue points in the OP's second illustration) using a low-profile jack like this one with pad and stay-in pucks from Southern Car Parts. It never occurred to me that the pucks might split or crack, but after 2.5 years on my C6 and then my C7 they show no signs of problems. Using the pad on the floor jack might help in this regard and I don't jack my car very high anyway--just enough to crawl under it allowing decent arm movement.
3. For safety, insert a jack stand with pad or block of wood at the "preferred location" (red). Never trust a jack alone to hold the car up while you're under it!
If I want to jack up both corners of one end I simply move the floor jack and another jack stand to the other side and repeat, leaving the first jack stand in the original location. You can jack the entire car up very quickly this way if you have four jack stands.
I tried the Harbor Freight crossbeam, but it is too wide for use on the front. It could be fabricated to work, but IMO it is unnecessary.
Old 01-05-2016, 03:23 PM
  #35
BlueFinn
BlueFinn's Avatar
BlueFinn,
Yes, thanks. I read that and it says to use the slots for the lift pucks. I have permanent lift pucks installed and don't know if they can be pried off. I am wondering if there is another location? Hope it never happens, but...
Old 09-28-2016, 11:46 AM
  #36
djnice
djnice's Avatar
Since my lift has long arms I will need to lift from the locations shown at the bottom of photo. Looks like you can make a pad that contacts the frame at those locations.
Old 09-28-2016, 12:12 PM
  #37
2DLIMIT
2DLIMIT's Avatar
Go to post #6 on page 1 to see a diagram of those locations.
To Decode the C7 Owners Manual - The Lift
Old 09-28-2016, 08:44 PM
  #38
djnice
djnice's Avatar
Your diagram is very nice, but it doesn't show the locations I am talking about. I am referring to the Edmunds photo above where they are lifting on the drivers side of the car. Which in your diagram would be where the ends of the blue bars attach to the frame.
Old 09-28-2016, 08:57 PM
  #39
C8Jake
C8Jake's Avatar
Received 5,415 Likes on 2,535 Posts
rocket science
Old 09-28-2016, 10:05 PM
  #40
KemahGT
KemahGT's Avatar
I keep a Chevy tow hook on top of the battery for that purpose.
Quick Reply: Decode the C7 Owners Manual - The Lift
