I've been looking at threads about intake cleaning when the back of the valves get coked-up. Technically, this does not appear to be a difficult task but in looking at the different cleaners that people are using, I was wondering if there is any such thing as an adapter whereby one could blast the area with walnut shells while using a vacuum at the same time to contain the mess. Has anyone seen or done the job in that manner? Is there a adapter of sorts available or are people just taping the snout of a garage vacuum together with the walnut shell blaster?
I think someone pointed out that BMW makes a special attachment that fits the intake port so you can do this, but I have not seen one for a Corvette.
I asked my dealer about cleaning the valves, and they said they just fog a cleaner through the PCV system, and do not mechanically try to clean the valves.
Is carbon build-up a thing with the C7? I just sold my 335d because of that problem, which was all but assured, and bought the car of my dreams to replace it.
I will be installing a catch-can right after my 2016 arrives. There's considerable controversy on this forum and others about the efficacy of this device but I figure the worst that could happen is nothing but a lightning of my wallet. My guess is that it will at least postpone the time before I have to pull the intake and clean the valves and intakes.
Ugh... direct injection seems plagued with this issue, no matter who is using it. I will likely put a catch can in for good measure as well, the last time I did that was on a turbo car I owned, never thought it would be needed on an NA vehicle. Thanks for the info!
in theory its going to be a problem for the corvette.
although it appears that not all cars will have the same rate of valve coking. I would guess the LT1 will have slower rate of valve coking over the earlier DI german engines.
we dont have a single documented high mileage LT1 engine to inspect. although going with the theory a high mileage LT1 should have valve coking.
I believe the next generation of GDI engines will be a lot better. its one of the reasons i wont be keeping my corvette long term.
I know that running meth injection on the 335 seemed to keep the entire intake tract clean (and actually reversed buildup by slowly cleaning it out). Maybe that could be an option for the C7.
You can fashion one, it will take time to mold a piece of plastic to fit the engine side, other side is easy, just needs to fit a shop vac. It could be done but when I completed the DIY, I didn't want to leave the engine exposed any longer than I have to. Next time I pull the intake manifold I can take measurements of each port.
Just know that if you are doing this cleaning fairly early, most of the oil/gunk is still "moist". Blasting dry walnut shell will have a sort of snowball effect and create clumps of oil/shell that cannot be sucked out, forcing you to get in there and manually extract the clumps. I believe I read on one of the Camaro forums that this happened. The walnut shell cleaning should be good for dried/caked on deposits but if you have any wet gunk, it may be more trouble than its worth.
It enters the intake system threw the brake booster vacuum. Crazy?
I have a problem with this method in that while the guy is saying its useful for GDI engines and indeed will clean the back of the valves I, for one, would not want all that crap washing into the cylinder while the car is running. I understand that carbon can be a pretty nasty abrasive. When I've got about 5000 miles on mine, I'll do it the old fashioned way.
I wondered about that, too. Also the effect on the cats.
I tried the spray stuff on a Ford Ecoboost sedan with GDI, I didn't think it worked that well. The stuff is really runny and dries really fast, I just don't see it working well for anything more than minimal deposits/film. Especially on a running engine with so much airflow, I doubt the fluid stays fluid on the back of the valves long enough.
I'm an advocate for catch cans after seeing my own engine. Just put it on, at least it will prevent alot of the oil. I plan to do the cleaning every 15k miles. GM is starting to integrate catch cans as well, I think LGMotorsports posted in the Z06 section about a new Camaro with the LT1 engine having an integrated catch can from factory (they had pics).
I have been checking into catch can setups, and it looks like the most complete system is from RX Speed Works, with thier dual valve catch can setup. Anyone used these? Any comments?
I installed the RX catch can. I picked it because it was one of the few that came with a valve on the bottom and emptying it is painless and no mess. There were a few negatives. I found the YouTube install video they posted had some differences with my car for some reason and the paper instructions were not very good. The video was better to follow. They do require you to cut one of the stock PVC hoses so it would have been better if they could have provided the exact plug and play fittings instead. I also had to obtain a few good quality hose clamps that they did not supply that they should have. All this being said, I would recommend it even though it is more expensive than others out there.
It does seem to work - when I open the valve to empty some black nasty looking oil comes out.
Jegs had it the cheapest by far at the time I bought it so shop around.
