Transparent top
Old Jan 11, 2016 | 06:49 PM
460HP-YLO-JAKT's Avatar
460HP-YLO-JAKT
Originally Posted by Hoonose
Look around for this sort of sun screen:
For whatever reason most seem to be on back order right now.
But in sunny AZ I will have to have one to use by April.
I have one of this type and it works well when needed. It's better to have along just in case needed ( just my opinion). I live in PNW but traveling to midwest or down south to Las Vegas.
Last edited by Zymurgy; Jan 11, 2016 at 08:56 PM. Reason: Link to non-supporting vendor removed
Old Jan 11, 2016 | 06:53 PM
Hopper12's Avatar
Hopper12
I don't doubt your numbers. But come April or so in AZ the sun radiation itself becomes uncomfortable while driving and a barrier is needed for that purpose. I had both tops with my '99.
I totally understand. I believe (could be wrong, but several forum members who have owned prior series transparent tops have stated this) that the C7 transparent tops are significantly different than prior series and much better and shading and keeping the heat out. Our C7 is our first, so I can't compare - I just know that it was never a problem for us in summer heat that went well over 100 degrees on several days. That said, AZ/NM, etc. are ovens in the summer.
Old Jan 11, 2016 | 07:41 PM
Hoonose's Avatar
Hoonose
I wasn't aware of any difference. I did notice significant radiation effect just recently, and it was only about 50 degrees. Instead of buying both roofs this time, I never had any doubts that I would be ordering a barrier of some kind before Spring.
Old Jan 11, 2016 | 08:21 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Originally Posted by joemessman
Good to know.
Joe, Just sent you a pm
Old Jan 11, 2016 | 09:04 PM
Richard Ames's Avatar
Richard Ames
Total temp difference by a member is about 3 degrees but was not a controlled or timed test. Any car candy heat up from conductive heat. I got a California Pop Top which is sold by the NCM as good as parking in shade.
Works is SWFL
Old Jan 11, 2016 | 09:28 PM
Hoonose's Avatar
Hoonose
Works is SWFL
If it ties down real good maybe I could cut out some holes to see while I drive?
(lol)
Old Jan 11, 2016 | 09:54 PM
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
I highly recommend. It comes right off if day not to hot.
Old Jan 11, 2016 | 10:03 PM
BIG Dave's Avatar
BIG Dave
Some people feel the transparent top makes the interior too hot, on the other hand, some people don't feel that way. Probably more of an issue if you live in the South. I live in the Northeast and I was never bothered by it. On my sixth Corvette and every one has had a transparent top.
Old Jan 11, 2016 | 10:27 PM
Astrowing's Avatar
Astrowing
The heat is not a problem, but I do wear a cap with the transparent top because I can feel the radiation. With the solid top, I don't feel that I need to do so. I am in Houston and travel to Austin and Waco.
Old Jan 11, 2016 | 11:04 PM
joemessman's Avatar
joemessman
I have both tops. Tested the heat transfer on a 95 degree day during the summer. Put the painted top on and left it in the sun for two hours. Then put the transparent top on and let it bake for 2.5 hours. The interior, measured by an accurate thermometer in the same spot in the interior, was 2 degrees warmer with the transparent top (but it baked for 1/2 hour longer too - had some stuff to get done and didn't get to it right at the two hour mark). Short story: no real difference, and I never use the painted top. Hope this helps.
Helps big time! I would buy you a beer if I ever ran into you. Thanks.
Old Jan 12, 2016 | 12:09 AM
pharmade's Avatar
pharmade
I'm in East Texas. Got a transparent roof because exposed carbon fiber was on constraint and I wanted to get my order in on a 2015. I was also fearful of the heat, so I ordered and received a roof liner even before my car arrived. The liner is still in the box, in my closet. Never used. The only thing I noticed that was questionable about the TP was increased daytime "brightness" (not heat). Definitely looks nice on Laguna Blue, though. I bought a pair of Maui Jim's and fixed the "brightness" during the day. At night, I love the transparent roof.
Old Jan 12, 2016 | 12:14 AM
Don't have a C7, but never found it necessary to put any kind of headliner in the car to keep it cooler.
Old Jan 12, 2016 | 10:31 AM
  #33
joemessman's Avatar
joemessman
I'm glad to hear that. When I ordered my car I really did think the tint would take care of most heat and excessive light and since I live in Portland it shouldn't be an issue. But when I read varying opinions on things like this I tend to over react. Thanks again for your input.
Old Jan 12, 2016 | 10:46 AM
  #34
tunaman's Avatar
tunaman
There is no comparison between the C5 transparent top and the C6/C7 transparent top. They got it right in the C6, and the C7 carries that on. Even in the most direct sunlight in regions with temps well over 100 degrees, the new generation tops provide ample protection and you will experience little, if any cabin temp difference.
My first C5 was a '97 with black interior, and being in the Inland Empire with temps well over 100 degrees the console and seats could blister skin.
We have had two C6's ('06 Z51, '12 GS) and had not found a need to use the solid tops, in spite of having them. We now have two C7's with transparent tops only.
Old Jan 12, 2016 | 11:22 AM
  #35
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Spot on tunaman. Those relating their heat issues from way back when really should not comment. There is no comparison, other than the fact that the new tinted polycarb top will keep the interior darn near just as cool as the painted one. And anyone that doesn't think GM spent long hours in the AZ desert sun measuring said interior temperature differences is highly mistaken.
Old Jan 12, 2016 | 12:45 PM
  #36
HDBADDOG55's Avatar
HDBADDOG55
Do any of you with transparent tops find it necessary find it necessary to use a cover to keep the heat out? And if so what would you recommend? Thanks.
This is what I bought. Works great.
http://www.rpidesigns.com/shop/item.aspx?itemid=4828
Old Jan 12, 2016 | 03:09 PM
  #37
Hopper12's Avatar
Hopper12
My pleasure! That's one reason I like this forum. Lots of good info. And a bit of periodic entertainment like 'is Z51 an option or a model', or 'M7 vs. A8', or...........
