CAGS Install Q
Old Jan 12, 2016 | 09:45 AM
DBLXX's Avatar
DBLXX
Default CAGS Install Q
If I own standard car ramps can the C7 base model be backed up on them with enough room in front and rear so it won't scrape and is there enough room to scoot under and install it?
I don't have access to a lift.
Old Jan 12, 2016 | 10:09 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Maybe. I have some rhino ramps that I use for my sons Honda, but the tires are too wide on my ride to fit. Clearance wasn't an issue though, so you might be ok.
Old Jan 12, 2016 | 11:20 AM
Bamac7's Avatar
Bamac7
I used the rhino ramps for my cags install. No issues with the front scraping and more than enough clearance to get under it. The back tires are a little wide for the ramps but not by much on the ramps I used.
Brett
Old Jan 12, 2016 | 07:15 PM
drs's Avatar
drs
I used ramps as well to install the cags defeat. Easily done.
To CAGS Install Q
