A8's and Torque Converter failure
#201
I took my 2015 in on Tuesday for an airbag recall and I asked them to look at the transmission while they had it. The 1st to 2nd shift is way too "mushy" for this sort of car, it shifts like an old Powerglide. I'd say it’s slipping but the tach doesn’t climb when it shifts. I thought it might need to be flashed and start to re-learn but they checked it out and told me it needs a new torque convertor. This will be the second time the torque convertor is replaced. Now I'm getting concerned.
#202
Just got my car back from the dealer after they fitted the new torque converter. The drive is much better, and the shuddering is long gone. However, I am experiencing some minor jittering every now and then, but I'd put that down to re-programming which should work its way out (fingers crossed!!!).
The car shakes slightly during cruise, but nevertheless it's not something you'd expect. The biggest issue that has developed is jerking during downshifts in traffic (especially with relatively hard or sudden braking), and at times with upshifts.
Haven't reported the issue yet, but GM are a going to get an earful. Not a happy customer.
#206
Shame on me ... this TC...tranny ...shaking...fly wheel etc problems have been going on for a long time ..no recall ...nothing ..just grief, aggravation. and depreciation ... never again !!!
Steve571 (10-27-2016)
#207
GM does not care ..they have no fix ....speaking for myself ..I knew better than to buy a GM product ..got really burned many years ago ...
#209
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
So.....I've got a question for you, bbcb.
You got burned "many years ago" by GM and you'll "never again" buy another GM product. But yet you just joined CorvetteForum a little over a year ago. If you'll "never again" buy a GM product, why did you join CorvetteForum in the first place????
Red C8 of Jax (10-28-2016)
#210
Wow! Let's see if we can make even more trial lawyers rich!
I can see it now, "accept the terms" and an A8 owner will get a $500 coupon toward the purchase of a new car! And the lawyers will get millions!
If mine breaks I think I'll just get it fixed.
#211
4
You are right a tiger never changes it's stripes. GM s history will never change. But we all know this but we like to hide it from ourselves. Torque tubes..unexplained cracked windshields..leaking oil through the intake. Blank info screens Etc etc All sad things. My 2011 C6 had a rear clicking sound. When tech found the service bulletin it was dated 2005. Simple fix.loose axel nut. Fixed with loctite...Never corrected at factory..rediculous.. My Toyotas and Honda give me over 150k miles without a hitch. And for those who say Japanese cars arent what they used to be, that may be true but they are still WAY ahead of GM in quality. And yes I have a C7. There are a boat load of used 2014s sitting on Chevrolet lots with low milage. ever wonder why so many ?? I have been under hoods for a long time 396 427 etc. When I heard new 8 speed auto, I knew to go right to a 7 speed manual , they can't screw up a clutch system too bad.,
GM does not care ..they have no fix ....speaking fory myself ..I knew better than to buy a GM product ..got really burned many years ago ...
#212
Come on, joining the Corvette Forum a year ago has nothing to do with bbcb not buying another GM product. The guy is frustrated with a lack of GM resolution for A8 Trans problems and he is not the only one. No better place than Corvette forum for information about his early build C7/ A8.
#213
I'm not pleased with the transmission issues, in fact I was a bit nervous about buying the 2015 since it was the first year with the A8 but I just had to have a C7. Right now I'm okay thanks to Stingray Chevrolet. It's a long ride from where I live but the local dealer simply insists that there's no issues. I don't even bother with them anymore expcept for oil changes. And that only because I don't have the dry sump! A good dealer makes all the difference in the world. However, I really hope this takes care of the problem.
#214
#215
#217
The answer may be Black & White
#219
2015 Z51 A8. Delivered Apr. 2015. Trans symptoms was a very harsh Park to Drive shift when sitting for 6 hours or more. This started after about a year of ownership. Took it to the dealer this summer and they reprogrammed the transmission. It worked for a few months, then back to the harsh shift. It's been in the shop now for 3 weeks and the TC is STILL on backorder....... Not happy.....
It's my own fault. I broke my own rule of never buying the first year of anything.
The service bulletin 16-NA-014 for the transmission issue is attached if anyone is interested...
#220
2015 Z-51 with A8 Issues Oklahoma area
Mine is in the shop now, getting the TC replaced. I have ~16K miles now, it started acting up somewhere around 10K. Hope this is the fix!!
