Vitesse Throttle Controller install/review
#181
A few reasons we've decided to change the design:
One single **** is much easier to use while driving, by turning the **** right or left to increase or decrease the Throttle response.
This new remote was designed in-house and we're very proud to say it is our unique design.
Lots of other companies are using now that same 2 button design, 90% of them are cheaply made knock-offs from China, they come in different sizes and shapes.
I also take this opportunity to explain a few differences:
Most other controllers will only amplify the signal by making the ECU / Throttle Body Blade think you have pushed the gas pedal much further than what you actually did, giving you more acceleration than needed.
Most other controllers will not decrease Lag (Throttle response ) which is the time it takes for your car to start acceleration after you have stepped on the gas pedal.
We use original OEM harnesses made by DELPHI, exact same one as your original harnesses.
#182
#183
Thanks for the explanation. I still really like the product. I keep it on 9. One of these days, when I can stand to do so, I will try dialing it back. But I keep asking myself why I would want to do that since it's so responsive on 9.
#185
So you're essentially saying that the delay is within the signal the throttle pedal and its associated electronics are sending and not upstream at the ECU (adding delay once a given throttle position were sent)? Which the Vitesse is intercepting, removing the delays the throttle's electronics would have added?
C82LT (07-24-2017)
#187
I installed my controller in the morning on the 4th. I removed the pedal and the connector came apart easily. I installed the control in the console and it was pretty straight forward.
Then like a dummy, when I went to calibrate it I forgot to hold the switch down while I turned it to accessory and got an error code.
I went back and disconnected it and started over and it worked fine.
I read reports of sp9 being too touchy so I started at 5.
There was a noticeable improvement but then I tried 9 and I really liked it. It didn't feel touchy or hard to contol. It was just fine on the freeway too. I have a M7 and the car seemed easier to drive from a dead stop.
I only had about 30 minutes before the rain came. Been raining ever since.
To me the car feels more responsive and it is much more enjoyable to drive from a dead stop, especially on a hill. A real good value. I should have installed a year ago.
Only problem is that it is hard to read the setting in the sunlight with the top down.
I highly recommend it.
John
John
#188
Ok,my question.
I'm ok with a little on throttle lag,but the off throttle lag is what bothers me the most.
Will it help with that too?
Thanks in advance.
\db2
Thanks in advance.
\db2
#189
If what you're referring to is being completely off the throttle and then getting back on the throttle, the controller eliminates that lag.
#190
I am really considering putting this on my C6. Has anyone had issues with this damaging the ECM or anything? Is this recommended for H/C/I modded car with a tune? I don't want to screw up my tune or ECM. That being said, 98% of what I have read has been positive so far on here.
#191
Received 1,694 Likes
St. Jude Donor '15
If your car is tuned, you should just have your tuner adjust the throttle response.
#192
I was thinking that as well but I like the idea that I can turn up or back off the throttle response manually as opposed to just being set in one mode on my ECM tune. I just don't want to screw up my tune or start throwing codes etc.
#193
You will need both:
A Ported Throttle Body will allow you to let more air volume into your engine.
A Throttle Controller will allow you to get that air volume a lot quicker into your engine.
#195
Asked above, but does your device actually eliminate lag or simply adjust tip in? You may have missed that question earlier. You implied that you eliminate lag.
#196
St. Jude Donor '15
I tried a ported tb before I got the Vitesse and the two aren't comparable. If you were doing other things along with the throttle body, then it adds up nicely, by itself, it makes a small difference but nothing like the Vitesse. I don't know about a tuned car though.
#198
#199
You have a one year warranty on the Controller and a 30 day money back guarantee. What is your concern ?
#200
From what I have heard is that the manuals have the lag and also I have talked to a owner of a 14 A6 that has a lag. My 15 A8 has no lag with a sensitive throttle response. The car is a Base with NPP , NO Mods but M/T DR's. Best 60' time of 1.633. Maybe the TQ management has increased on the 16 & 17's that shows up on the throttle responsiveness.
