No more 93 octane pure gas in NC
Pure gasoline stoic is 14.7-1 your new car is stoic at 14.108 and tries to go there which is perfect for E 10 but rich for pure gas and there is no trimming to lean it out because the ECU wants 14.108 only which is rich for pure gas.The oxygen sensors are not monitored under full power as they are narrowband and incapable of measuring A/F under power enrichment and as sophisticated as the cars are they simply go to a dumb program at full power and they are commanded to optimize for E 10 not pure gas.
JerryU (06-13-2019)
Sorry, but that’s mostly not true. While true that the O2 sensors do not respond quickly enough and are not monitored during a full throttle burst, the fuel trims that have been determined during the immediately preceding cruise phase are applied. You are also using stoic a bit wrong. The goal of the ECM is to run very close to 1:1 stoichiometry at all times on all fuels. Stoichiometry of 1:1 is equivalent to an A/F ratio of about 14.7 on pure gas and 14.1 on E10. The fuel trim is what varies the A/F ratio to keep the stoichiometry near 1:1 for all fuels. When you go to fuel enrichment during full throttle, A/F drops a bit, I can’t quote you the exact amount. But suppose you are running E10 which would have a fuel trim near zero, and the table called for A/F to drop by 0.5 to 13.6. If that same car was running E0, fuel trim would have cause the cruising A/F to be about 14.7, and if you floored it, A/F would again drop by the table’s 0.5, making it 14.2. So you’d get the same and correct degree of fuel enrichment running both E0 and E10.
The C5 and the C6 had the GM installed tune set up for 14.7. They were set up for pure gas, not E10.
For the C7, GM changed the tune for 14.1. They are set up for E10, not pure gas.
It does make a slight difference in performance, depending on how the car is tuned( for 14.7 or 14.1)and what gas you run in that particular car.
Received 2,639 Likes
The one time I ran pure gas in a C6 the extra mpg's and performance wasn't worth the extra dollars the gas cost. Plus, these cars were designed to run ethanol gas. Outside of that one time 93 octane E10 is what I've ran since my first C6. Top Tier of course.
I got better MPG with pure gas, but the same $/Mile result, with either pure gas or the ethanol blend.
Rebel Yell (06-14-2019)
E15 on the horizon
This week, President Trump announced E15 would become the standard gasoline grade...so we can help the corn farmers. Any thoughts about how our cars will perform on this fuel?
#33
Received 3,818 Likes
I just use the highest octane available wherever I am at. It varies by state and season. I never buy on price and I only go to Top Tier stations, usually Shell or Chevron because that's what is around here. I don't track, so there's no reason to worry about any of this other stuff. No worries and running fine.
#34
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Works great in my m/c and the zero turn-mower. It seems to keep the carb much cleaner.
#35
The uncertainty is the degree, if any, to which E15 is more corrosive than E10, and thus represents an increased risk of failure to things like fuel pumps, fuel lines, gaskets, and other components in direct contact with the fuel. This is where I don’t have firsthand knowledge since my retirement, but my sense is that the risk is fairly low. The reason I say that is that essentially all of the articles warning about that come from sources that made similar dire claims about E10 in years gone by, so their credibility is at least somewhat questionable. Even with the car companies that object, their credibility in resisting change leaves something to be desired. So I guess overall, while I dislike the economic/political stupidity of E15 about 1.5 times as much as E10, I’m not overly concerned that it will be a maintenance disaster.
#36
I don’t have detailed firsthand knowledge about E15, as it was not being seriously considered when I retired. However, certain things are clear, as outlined in this first paragraph. Uncertainties are in the last paragraph. There should not be any problems with the ECM, injectors, engine performance, horsepower, drivability, etc. All of those should perform as in earlier posts, simply adjusting to A/F of about 13.8 instead of the 14.7 for pure gas or 14.1 for E10. That’s well within the adjustment range of cars built since the late 1990’s. Flex fuel capability is not needed. Mileage loss will increase from 2-3% for E10 to 3-5% for E15. Air pollution will increase slightly during the summer because ethanol is high vapor pressure, so a summer vapor pressure waiver will be required, and a bit more unburned fuel will escape to the atmosphere. There’s a bit of irony there for something that’s supposed to be environmentally friendly, but it’s not a problem for the car. And of course the economic insanity for zero benefit to anyone but politicians, farmers, and ethanol plant owners will get worse. But none of the above represents a risk to the car or a threat to reduce the performance (other than gas mileage) of the car.
Thank you sir. It's good to hear from someone that is knowledgeable on a subject, and also has some skin skin the game.
#37
E0 fuel IS NOT off road fuel..leaded race gas is..in Wisconsin, fuel that is off road is labeled as such..if you aren t in the 6 ciunty area around Milwaukee, you can buy ethanol free premium all over the state..
#38
Received 19,293 Likes
'20-'21-'22-'23-'24
Revival of a five year old thread.
