Warble sound occasionally
#1562
Checking in guys hoping your new yr. is all good. Hope you guys with the Warble are getting them fixed and enjoying your awesome car. Not much chatter or posts on the warble so that is a good thing. Take care
#1567
#1568
The warble should occur at 1500 RPM irregardless of what gear you're in. Most likely will occur on a slight incline in 8th gear at about 75 MPH. Find a place where your car will warble and does so consistently. Then go to the dealer and insist that YOU drive the car. There's too many mechanics out there that do not want to do the work and, "Just can't hear a thing." or "That's normal". The warble is caused by a problem with shims in the diff causing a misalignment with the ring and pinion. I don't think GM figured it out until fairly recently and that's why some folks are having to replace more than one diff. Have your dealer call the Technical Assistance Center for more info and insure that he does. Document everything. GM is only the problem here to the extent that they couldn't get this mess figured out. In my experience communicating with people about it, the dealers are the real PITA.
#1569
Received 2,639 Likes
Mine has been doing fine, but on occasions I think I can hear it a little. I don't know if that's just me expecting the warble, or it's really there. At this point I feel it would be a fruitless endeavor to take her to the dealer. I have an extended warranty, so I guess I'm gonna just drive the car until the warble visits again.
rmorin1249 (01-16-2018)
#1571
Received 1,738 Likes
St. Jude Donor '15-'16,'18
Rebel Yell (01-16-2018)
#1573
Traded mine in with the warble. Not because of the warble though.
#1574
I know very few (if any) Z06s had the warble. I really believe mine did as it matched all the symptoms (specific RPMs, specific sound etc.). In the past 10k miles I have had new and different tires (Pirelli runflats) put on and have had the torque converter issue looked at with the current solution being a triple flush. I am not noticing the warble anymore, not sure if it is related to any of the changes however (but I'll take it LOL).
The following 2 users liked this post by terry50:
bjones7131 (01-17-2018),
Rebel Yell (01-17-2018)
#1576
Arctic C7 what was the outcome of your last visit you wrote about on April 15, 2016? Did you get it all resolved? I have the same noise, "Tweety bird" I call it. I have a 2014 A6, which I bought used. I am trying to understand what is the real problem here and then will go to the Range Disabler.
#1577
they said the vibration was comming from the tc. they changed the oil in it, and also changed the trans oil. they told me to drive it 200 miles and see what happens. i atill hear it a little at 1500 r,p,m. in 6th or 7th gear. ill keep you posted
#1578
#1579
Received 2,371 Likes
Misery Loves Company
Our tweety 'noise' is at 46-48 mph 2014 A6 base suspension convertible. Harmonic related since it shows up at 46 and goes away at 50. Like having no hair, I've learned to live with it. And so it goes.
