Chevy's Oil Life Monitoring System...What a SCAM!
I have a Z51 and recently had the oil changed...With Mobil 1
After less than 700 miles, the OLMS is telling me that I have
47% oil life remaining!!!!
That is preposterous!!!!
I have not driven her at all hard since I had the oil changed...
I mean if I drove her like the "Fast and Furious" every day,
perhaps the oil change recommendation would make sense...but
I can discern no reason for this warning other than perhaps
GM has invested in oil company stock...
The Mobil 1 is supposed to last ten times longer than that!
I am just going to go by mileage and ignore this useless OLMS...
What have been your experiences?
Popular Reply
04-16-2016, 07:57 PM
It is actually a very good system. It takes many variables into account, time included.
The following 6 users liked this post by Kracka:
blkvet6 (02-04-2017),
Brubie (04-16-2016),
Chemdawg99 (04-17-2016),
dpb (04-17-2016),
Edmond (02-04-2017),
and 1 others liked this post.
For who?
Mobil?
The dealer,
Absolutely!
And what variable does "time" play?
It's only been a couple of months and I'm at 47%????
This OLMS is nothing but a consumer rip off!
upcharger (02-08-2017)
Received 3,818 Likes
Last time my OLMS told me I needed an change at 7500 miles and a year, which is pretty much on the money.
The following 6 users liked this post by mschuyler:
Bob Yocum (04-16-2016),
gurneyeagle (04-20-2016),
Jbal (02-03-2017),
rogergcam (04-24-2016),
Received 3,114 Likes
Finalist 2020 C7 of the Year -- Unmodified
This suggestion that it is a conspiracy is absurd. Relax. Wait until the car tells you it's time for an oil change before you have a conniption fit over this. Then follow it or don't. It's not required.
they change it, unless they know like you do apparently that it is optional.
I haven't had a "time to change oil message" because I never let it get down to single digits....I mean, what is the point of having an OLMS that is wildly inaccurate other than to get you to run in and get an unnecessary oil change?
Well, I'm heading out for the evening...probably be down to 41% or less before I get home....
Mine has been very consistent and gives me about 7,500 miles before the ten percent mark. I also drive ~22,000 miles a year, so I doubt it takes "time" into too much consideration for me.
rothchilds (04-17-2016)
I should really do a test next time, but my contention is that the OLMS is NOT lineal and that you actually have some time before it gets to near zero and the OnStar system starts bugging you about it with an e-mail. Mine even emails my dealer, so my dealer emails me and says, "Hey, OnStar says you need an oil change!" So I say, "OK. Fine. Come get it!" and they do, and it's free anyway (for now)
I'm thinking of killing my OnStar because it's bugging me, but on the other hand it tells me when my tire pressure is low. I find that the run-flats are terribly difficult to control. I have a good compressor and everything, but getting those run flats perfect is a real PITA. (Off topic. Sorry!)
Received 1,694 Likes
St. Jude Donor '15
Don't change it then. It's your car, you can follow whatever guidelines you think are best.
Woodson (04-21-2016)
The OLM is time dependent. It will let you know to change the oil at least once every year because that is what is required to keep your warranty in effect.
I think you are perhaps inadvertently throwing some confusion into the issue. The manual on my 2014 C7 says "The engine oil and filter must be changed at least once a year...." It also says you could go beyond a year under optimal conditions if you just looked at the OLM but the annual change drives everything, no matter how little or much you drive the car. Don
I am now SO confused!
Well, I suspect that most people don't wait for the OLMS to get down to 0% before changing their supposedly long lasting Mobil1 oil....
Just as a personal example, my Z06 had its initial oil change at about 580 miles. The second change came at 9 months and 4600 miles later with the OLMS indicating 16% Oil Life remaining.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
The following 5 users liked this post by MikeyTX:
cor66vette (02-04-2017),
owc6 (04-16-2016),
I had this when traveling from KC to Denver. I started out in a 55 degree rainstorm before dawn, and it was 95 degrees when I arrived in Denver that afternoon.
And certainly, relying on the DIC to tell you accurately the pressure when either filling up or letting air loose is not a good idea: the car does not sample often enough to get an accurate fill amount.
1776DAVE (04-21-2016)
