Gtechnique coating, any opinions?
Their C1 crystal lacquer topped with their Exo coating looks interesting. I hope to have my new C7 in 2-3 weeks and haven't yet decided on a coating. I'm looking for ease of application, durability, gloss and good hydrophobic action. This is going to be a do it yourself application, after a light polish. I've heard some products, like Cquartz can't be a bit tricky to apply. I don't want to make a mess of my new car finish. Cquartz UK was my first choice, but I becoming a bit unsure. Also, any recommendations on wheel coatings? I'm getting white with black wheels.
Received 1,694 Likes
St. Jude Donor '15
I haven't heard of gtechnique, if you use it I'll be curious to see your results and impressions. I use Blackfire crystal seal, it doesn't get much easier to apply than that. Spray on and wipe off, works great. It's a sealant, not a ceramic coating though.
For the wheels, I use a product called hydro2. That's a silicant hydrophobic sealant. Spritz it on when wet and blast it off with the hose. Its easy and seems to work pretty well, the wheels just need more attention if that stuff bothers you, plus they get beat to hell if you drive your car. Good luck!
Received 1,033 Likes
St. Jude Donor '09-'10
Just did our black cars in Wolfgang Uber Ceramic coating after correcting minor swirls with Wolfgang Twins. Uber coating VERY easy to apply w respect to high spots that sometimes trouble other coatings.
I any case the coatings are only as good as the prep work done before application. For a DIY project make sure that the paint is clayed and buffed to perfection then wipe it down with an alcohol mix. Apply the coating on one panel at a time and use a timer to be sure you remove it at the right time. It took me about 25 hours to prep and coat my 2015 DSOM C7 but that is because I was very particular and took my time. 18 months later and the car still looks as good as the day I coated it. I did use the Gtechnique made for glass because the 22ple brand was out of stock. Both work very well. I highly recommend coating over sealants or waxes but if you plan to use a clear bra it has to go on before the coating.
I am not a professional detailer but I have been detailing my cars and some of my friends for many years. Products are constantly changing. There is always great advice on this forum.
2015 C7 DSOM
McLaren MP4-12C
2016 Porsche GT4
I had my car professionally polish and then done with the 2 coat process. It looks amazing. I also have Xpel Untimate done at the same time. The polishing got rid of a lot of orange peel.
Almost 2 years and 22k miles, it still looks the same.
I would highly recommend having a professional prep/coat the car unless you have experience in that arena. I've used a few different coatings and by far my favorite is Ceramic Pro 9H. It's supposed to be permanent and you can get it done in multiple layers, it blew away the opticoat and 22ple coatings! Good luck, I have all of my cars coated and its been worth it on every one.
