View Poll Results: As a 2015-2016 A8 owner...
I am not interested in changing my trans oil cooling system.
38
25.00%
I would definitely want the upgraded trans oil cooling system even if I have to pay for it.
27
17.76%
I would definitely want the upgraded trans oil cooling system if I didn't have to pay for it.
87
57.24%
Voters: 152. You may not vote on this poll
A8 Owners - Transmission Oil Cooling System Upgrade Poll
#81
Are the 2016 Z51's still having issues with the A8 transmission overheating on the track? I thought the 2016's had additional cooling that solved the issues. I was about to pull the trigger on a 2016 this Thursday. I do plan to track it at Mid Ohio and Putnam.
#82
Received 9,513 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
I have been authorized to share the following information about transmission cooling upgrades for the 2017 Corvette model year. Transmission cooling improvements are included with all 2017 Z51 automatic transmission Stingray and Grand Sport Corvettes. Furthermore, the manual Z06 and 8 speed Z06 will both receive cooling improvements as well. The cooling improvements will bring the track operating temperature threshold to 100 degrees.
#83
Thanks for that update. What's the story with base A8 models?
#84
2015 C7 of the Year
#85
So when you ask about applying this upgrading cooling package, the base A8 is not being considered? What additional parts/work would be needed?
#86
2015 C7 of the Year
I'm sorry, I should have said no upgrade to the base A8 2017. The kit very well may be applicable to the base A8 if someone wanted to upgrade a pre-2017.
#87
I believe that GM should do the right thing for its loyal customers. It is clear to me that there is a product defect, which hopefully this FIX will solve.
Step up GM, and issue a TSB to have the dealers fix under warranty.
#88
So no "kit" to fix the 2015 A8's will be released?
#89
#90
This shouldnt even be a problem for us to worry about. I myself have become a fanboy.
Zl1 is gonna wipe the track with z06s. Time for corvette to take pointers from camaro...and while they are at it...give camaro's engineer a shot at the vette's top office... After many vettes, I currently have a camaro 1le and im gonna miss that car. Helluva job by camaro. Shame on the cross flags.
Tadge may be annoyed at the shade tree engineers all have been forced to become. Desperate for a solution outside of their expertise...this is why customers PAY...so they dont have to be engineers.
#91
Bill
jagamajajaran (09-20-2016)
#92
2015 C7 of the Year
The 2017 Z51 8-speed vehicles will receive the front lay down auxiliary transmission cooler. This is the same cooler the GS and Z06 use. There will be a service communication to provide instruction on how to add the front auxiliary cooler to a past model 8-speed Z51. For the owner’s information, to add the front cooler the following body parts will have to be removed; front/rear fascias, left fender, left quarter panel.
#93
Thanks Jag. I appreciate it. Although I have not installed it yet, I think the cooler in the left rear quarter panel is the Z06 cooler but with the smaller Z51 fan and the Z06 duct. I will list those part numbers in the thread I started about the "kit". Again...I have not installed the larger rear cooler but am told by a reliable source that it will fit with the smaller fan.
thanks
bill
thanks
bill
#94
So if I understand that correctly, the 2017 Z51 8 speed is exactly the same as the 2016 (no improvement). Which is fine because the 2016 improvement seems to make a big difference.
Now the "service communication" is definitely different than the past promise of an "upgrade kit" for earlier models. Is there a date on the "service communication"?
The following 2 users liked this post by Jay_Davis:
Azul (09-20-2016),
#95
#96
2015 C7 of the Year
A date for the "service communication" was not provided, but the components of the kit should be provided.
